Find frictional torque acting on the pulley?
  • Thread starter Thread starter saturn67
    Pulley Torque
The discussion revolves around calculating the average frictional torque acting on a pulley with two hanging masses. The participants initially struggle with the equations of motion and torque, particularly in determining the correct tensions and acceleration. They clarify that both masses share the same acceleration due to their connection via a string. After several iterations and corrections to their equations, they successfully compute the frictional torque as 0.5 mN. The conversation highlights the importance of accurately applying Newton's laws and understanding the relationship between torque, tension, and acceleration.
saturn67
A string passing over a pulley has a 3.75 kg mass hanging from one end and a 2.70 kg mass hanging from the other end. The pulley is a uniform solid cylinder of radius 4.8 cm and mass 0.75 kg.
In fact, it is found that if the heavier mass is given a downward speed of 0.23 m/s, it comes to rest in 6.7 s. What is the average frictional torque acting on the pulley?
sum of torque = I*alpha
I = (1/2)mR^2
a=R*alpha
T1*R-T2R- frictional torque=I*alpha
i use that and i got around 0.415mN which is wrong ...
anyone give me some pointer please
That's the torque equation--good! But you'll need other equations to solve for the tensions. (Analyze the forces on each mass.)
T1=M1*g-M1*a
T2=M2*a+M2*g
this is right?
do i use the same "a" for each one?
saturn67 said:
T1=M1*g-M1*a
T2=M2*a+M2*g
this is right?
Good.
Yes--they are connected by a string so they must have the same acceleration.
... i got 2.95873mN for friction ... still wrong
do we use time for some thing?
T1=35.8875N
T1*R=1.7226
T2=-25.839
T2*R=-1.24027
I=0.000864
alpha=4.79167
i use all that and got 2.95873mN
Sure. You need it to compute the acceleration. (Note that the acceleration of the heavier mass is upward, so we need to double check the signs in your equations.)
T1-M1*g=M1*a
how we use time to find acceleration??
since we have the giving acceleration, time: this is where i have no idea >.<
clarification
saturn67 said:
T1=M1*g-M1*a
T2=M2*a+M2*g
Assuming T1 is the heavier mass, let's try it again. Write the equations this way:
T1 - M1*g = + M1*a
T2 - M2*g = - M2*a
Now "a" is just the magnitude of the acceleration, which you can calculate directly.
saturn67 said:
T1-M1*g=M1*a
Good.
What's the definition of acceleration?
We need to fix the sign of the acceleration in this one also:
-T1*R + T2*R + frictional torque = I*alpha
Now alpha is a positive quantity.
where can i get T1 or T2
since we have 2 equation and 3 unknow
T1,T2 and a
You have 3 equations and 3 unknowns. The acceleration is not an unknown. (It's easy to calculate from the given data.)
a= R* alpha
alpha=a/R??
acceleration = change in v / change in time
Vf=Vo+at
a=0.034328m/s^2
right?
saturn67 said:
Vf=Vo+at
a=0.034328m/s^2
right?
Right!
T1 - M1*g = + M1*a (found T1)
T2 - M2*g = - M2*a (found T2)
I=0.000864
frictional =0.5mN
WOOT it work
BIG thank! Doc Al for help me
You are most welcome. :smile:
