Find if the boat will see the flare, what angle will they?
  • Thread starter Thread starter Charlene
    Angle Boat Range
The problem involves a scenario where a flare gun is fired from a deserted island towards a ship located offshore. The objective is to determine if the flare will be visible to the ship based on the angle and initial velocity of the flare. The subject area includes projectile motion and kinematics.
  • Participants discuss the use of the range formula to calculate the horizontal distance the flare will travel. There are questions about the correct interpretation of the formulas and whether the calculations reflect the intended outcomes. Some participants explore the implications of firing angles on visibility.
The discussion is ongoing with participants examining different methods to calculate the range of the flare. There is recognition of the need to differentiate between vertical and horizontal components of motion. Some guidance has been offered regarding the use of the range formula, but no consensus has been reached on the correct approach or final angle.
Participants note that the problem does not specify the height the flare must reach, focusing instead on the horizontal distance required for visibility. There is also mention of the constraints imposed by the visibility range of the ship.
Charlene
You have been stranded on a deserted island. Fortunately, you managed to bring a flare gun. You can see a ship 300. m off shore. Unfortunately, because of the daylight the ship cannot see your flare unless it is within 100. m of the ship.
A.) If you fire the flare gun from the shore line with an initial velocity of 161 km/hr at an angle of 33.3 degrees , will they see your flare? (You must show your work in explaining why/why not.)
B.) With this same initial speed, is there an angle you could fire that would allow them to see your flare? If so, what is that angle?
R= (vi^2sin2(theta))/g
plugging in the known information i get R=((44.72m/s)^2(sin(66.6))/9.8m/s^2 =187.
would this be correct? or is calculating the range just the x distance?
and i know 45 degrees is where the max is so for part b) i would plug in 45 degrees into the formula to get around 200. and therefore they'd see the flare.
When i initially did this problem i used the formula v^2=u^2+2as
u=44.72 m/s (sin(33.3)=24.6
a=-9.8 m/s^2
plugging in i got
0=(25.6^2)+2(-9.8)s
s=30.76
and this got me a distance of 30.76 (which is COMPLETELY different than the other formula. what is the correct way?
okay, so relooking at this i see that using range is how FAR it goes (horizontally) and the second way i showed is actually showing the max height it hits. so since I'm just looking for the flare to get at least 200.m off shore I'm assuming range is therefore the correct approach.
Would this be correct to think?
u*sin(33.3) will give the vertical velocity and distance not the horizontal range
okay, that's what i thought, therefore i would want to use the range formula R=((44.72m/s)^2(sin(66.6))/9.8m/s^2 =187. because this will give the horizontal distance which is all this question is really wanting i think, because it doesn't tell me about how high the flare needs to be, just how close to the boat it needs to be.
Yes exactly. And for the second part you can find the angle taking S as 200 in the same range formula and finding the angle. You may get a range of angles with 45 deg as the mid point of that range
