Find M, Mx, and My for a thin plate if density=ky
  • Thread starter Thread starter cloudboy
    Plate
The problem involves finding the mass (M), and the moments about the x-axis (Mx) and y-axis (My) for a thin plate with a density function defined as ky. The plate is bounded by the curves y = 2 - x and y = 4 - x², leading to a discussion on the appropriate setup for integrals.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss setting up integrals for mass and moments, with some suggesting a double integral approach to simplify the calculations. There is mention of using horizontal elements and the challenges of integrating the given functions. Some participants express confusion about notation and the integration process.
The discussion is active, with participants sharing their attempts at setting up the integrals and calculating values. There is a mix of approaches being explored, and some guidance has been offered regarding the use of double integrals. Participants are questioning their calculations and the limits of integration, indicating a productive exploration of the problem.
Some participants note that they are in early stages of calculus, which may affect their understanding of the notation and methods being discussed. There are also references to specific limits of integration and the intersections of the bounding curves, which are under consideration.
cloudboy
Set up integrals to find M, Mx, and My for the thin plate if d(x)=ky
bounded by y=2-x and y = 4-x^2 or x = sqrt(4-y)
M = [itex]\int[/itex] dm = [itex]\int[/itex]d(x)dA
Mx = [itex]\int[/itex]ydm
My = [itex]\int[/itex]xdm
I broke this down into three equations. x1 = 2-y; x2 = -sqrt(4-y), x3= sqrt(4-y)
I used horizontal elements so that d(x) is constant across the entire element.
When calculating M, I got [itex]\int[/itex](ky)(x2-x1)dy = [itex]\int[/itex](0→3)(ky)(sqrt(4-y))-(2-y)dy + [itex]\int[/itex](3→4)(ky)(sqrt(4-y))-(-sqrt(4-y))dy
I got this down to:
k[itex]\int[/itex](0→3)(y2-2y+ysqrt(4-y))dy + 2k[itex]\int[/itex](3→4)(ysqrt(4-y))dy
The problem is basically that I can't figure out how to integrate these to find the total mass. Please help thanks!
I feel it would be much simpler to handle this as a double integral, integrating wrt y first. That will avoid surds in the bounds.
It very well may, I just haven't learned anything about that yet.
EDIT -- I am looking up double integrals, how would you apply it here?
In x-y co-ordinates, an element of area is dxdy (or dydx - either will do).
So the mass of lamina covering a region A is [itex]\int_{(x,y) \in A}ρ(x,y) dx dy[/itex]. If the area is bounded by f(x)<y<g(x) and a<x<b then you can write M = [itex]\int_{x=a}^b\int_{y=f(x)}^{g(x)}\rho(x,y) dy dx[/itex]
Ok I'm in my first calculus class and some of unfortunately I don't even recognize some of your notation. But I do understand somewhat and will try to use this. Thanks very much.
ok i am trying to figure this out. but my density function is ky, where k is some constant. it doesn't have an x value
The plate is bounded by [itex]y= 4- x^2[/itex] and by [itex]y= 2- x[/itex] which intersect when [itex]y= 4- x^2= 2- x[/itex] or [itex]x^2- x- 2= (x- 2)(x+ 1)= 0[/itex]
With density ky, the mass is given by
[tex]M= \int_{x=-1}^2 \int_{y= 2-x}^{4- x^2} ky dydx[/tex]
ok I watched a couple videos on youtube and this is what I came up with:
⇔ k[itex]\int_{y=2-x}^{4- x^2} ydy[/itex]
= k (y2/2) = k [(4-x^2)/2 - (2-x)/2]
= k/2 [4-x^2 - 2+x]
= k/2 [-x^2+x-2]
then
[tex]M= \int_{x=-1}^2 (k/2 [-x^2+x-2]) dx[/tex]
= (k/2)[(-x^3)/3 + (x^2)/2 +2x]from -1->2
= ... = 9k/4
how bad is it?
That's My, right?
No, you've dropped a power of 2. Setting y = 4- x2 in y2/2 gives (4- x2)2/2
Ok I did it again making sure to get the powers correct and I got M = 44k/5.
I calculated My to be 9k/2.
When I divided My/M to get xbar I got 88/45 which can't be right!
I don't get quite the same. I have M = 31/6, My = 549/310, giving ybar (not xbar!) about 1.8. That's quite close to what you have, and seems perfectly reasonable to me.
That's strange. I thought xbar = My/M ? Maybe I am getting my limits messed up, I evaluated My from 0->3, because from 3->4 is symmetric.
No. ∫∫ydydx/∫∫dydx must be computing an average value of y.
What is from 0 to 3? x? The x range is determined by where the two curves meet.
  • · Replies 21 ·
