Find moment of Inertia from Force, radius and acceleration
The discussion revolves around calculating the moment of inertia for a disc-shaped object subjected to a tangential force. The initial attempt incorrectly applied linear equations instead of rotational dynamics. The correct approach involves using Newton's second law for rotation, expressed as torque (r * F) equating to the product of moment of inertia (I) and angular acceleration (α). The final formula derived is I = rF/α, clarifying the relationship between force, radius, and angular acceleration. Understanding the distinction between linear and angular quantities is crucial for solving such problems.
iva
A disc shaped object is made of a non-uniform material. Its radius is r and it is fre to rotate about an axis through its centre. If a force F applied tangentially at the edge of the object produces the angular acceleration a, what is its moment of inertia for rotation about the axis?
I=mr2
F=ma
If F=ma then m=F/a
so that i=mr2 becomes I=Fr2/a
The answer in the book is I=Fr/a
Where did i go wrong? is it something to do with the force being tangent to the disc that i didn't do something?
Thanks!
iva said:
If F=ma then m=F/a
Careful. "a" is the angular acceleration, not the linear acceleration. (It's better to use alpha for angular acceleration.) What's Newton's law for rotation?
That formula for moment of inertia does not apply here.
All you need is Newton's 2nd law for rotation.
Thanks i get it now,
So all i really needed was 1 equation:
rotational force equation: r* F=I * alpha so I=rF/alpha right?
Right!
