Find momentum of pieces of shrapnel
  • Thread starter Thread starter Chrisleo13
    Momentum
The discussion centers on calculating the momentum and trajectory of shrapnel from a detonated artillery shell with a mass of 10.00 kg. Two pieces of shrapnel, weighing 1.70 kg and 3.40 kg, are propelled in the -x and -y directions at speeds of 21.0 m/s and 13.9 m/s, respectively. The remaining piece's angle relative to the +x axis can be determined using vector addition and the tangent function. The speed of the third piece is calculated by dividing the resultant momentum by its mass, which is 4.90 kg.
  • Understanding of conservation of momentum
  • Familiarity with vector addition and components
  • Knowledge of trigonometric functions, specifically tangent
  • Basic principles of physics related to motion and forces
  • Study vector addition in physics to enhance understanding of momentum calculations
  • Learn about conservation laws in physics, particularly momentum conservation
  • Explore trigonometric functions and their applications in physics problems
  • Review examples of projectile motion to solidify concepts of angles and velocities
Students and educators in physics, particularly those focusing on mechanics and momentum, as well as anyone involved in solving real-world problems related to explosions and projectile motion.
Chrisleo13
An artillery shell of mass 10.00 kg, lying at rest on the ground, accidentally detonates, exploding into three pieces of shrapnel. One piece of mass 1.70 kg is flung in the -x direction at 21.0 m/s, while a second piece of mass 3.40 kg is propelled in the -y direction at 13.9 m/s. Determine the angle at which the remaining piece of shrapnel travels, relative to the +x axis.
b. Calculate the speed of the third piece of shrapnel.
I found the momentum for 1 and 2 and I tried to invert those to try to find the third. I'm sort of lost on how to find the angle and such.
Thanks in advance.
Thanks in advance.
You almost have it then. Since there is a conservation of momentum and since momentum is a vector (you know like V is a vector) then the 2 momentum vectors must add to the third to give you 0.
\vec 3 = - (\vec 1 +\vec 2) = - ( m_1v_1 * \hat x + m_2v_2 * \hat y)
To calculate the speed then divide the resultant momentum magnitude by the remainder of the mass from the 10 kg. (I think you are supposed to assume negligible mass of actual explosive is exploded.)
Ok, I understand that but what is x and y in that equation?
m1v1(x) + m2v2(y)
what are the x and y variables here?
m1v1(x) + m2v2(y)
Those are the unit vectors in the x and y direction, because the resultant vector necessarily has both an x and y component to balance the x direction of vector 1 and the y direction of vector 2.
Hmm, I think I understand, but the unit vectors aren't given. Do I have to find them using the speeds?
I used the unit vectors as a device to emphasize the direction. In actuality they are length 1, in the x,y direction. The magnitudes are the scalar quantities represented by the momentums.
The important concept is that you must treat the momentums in the orthogonal directions separately and they must balance to 0. Momentums in x = 0 and momentums in y = 0. The resulting components define then the resultant vector.
Hmm, sorry for keep bothering you but I seem to miss the problem when I work it like that.
I got 82.96 when I added m1v1 to m2v2
then I divided it by 4.9 to find the speed. But that's not correct.
No that can't be correct. These components are at right angles to each other.
Think vectors.
Think Pythagoras.
Ahhhh, why didn't I think of that before. I got it. The angle still is unclear. Can I just take the tan of the two velocities?
That should work.
Remember though the direction is opposite the III quadrant as the x,y directions of the other pieces are negative.
I did
13.9 m/s / 21.0 m/s
tan-1()
then I should subtract that angle from 270 or 180?
Chrisleo13 said:
I did
13.9 m/s / 21.0 m/s
tan-1()
They want the angle with respect to the positive X axis. Draw a picture.
Well, I may have it. I have one try left on my homework.
I drew it out and found that it would be the opposite of what I said previously.
  • · Replies 38 ·
