Find Probability: P(Z $\leq$ 9/5)
  • Context:
  • Thread starter Thread starter mathmari
    Probability
9 replies · 2K views
mathmari
MHB
Hey! :o
I saw the following exercise and I wanted to solve it,but I got stuck.. (Worried)
Let $X,Y$ be independent random variables,that follow uniform distribution on $[0,1]$, and let the random variable $Z=X+Y$.
The density of $Z$ is:
$$f_{X+Y}(z)=\int_0^z f_X(x)f_Y(z-x)dx$$
How could we calculate the probability $P(Z \leq \frac{9}{5})$? (Wondering)
mathmari said:
Hey! :o
Hi! ;)
Let's evaluate your integral:
\begin{aligned}
f_{Z}(z) = f_{X+Y}(z) &= \int_0^z f_X(x)f_Y(z-x)\,dx \\
&= \begin{cases}
\int_0^z 1 \cdot f_Y(z-x)\,dx &\text{if } 0 \le z < 1 \\
\int_0^1 1 \cdot f_Y(z-x)\,dx &\text{if } 1 \le z \le 2 \\
0 & \text{otherwise}
\end{cases} \\
&= \begin{cases}
\int_0^z 1 \cdot 1\,dx &\text{if } 0 \le z < 1 \\
\int_{z-1}^1 1 \cdot 1\,dx &\text{if } 1 \le z \le 2 \\
\end{cases} \\
&= \begin{cases}
z &\text{if } 0 \le z < 1 \\
2-z &\text{if } 1 \le z \le 2 \\
\end{cases} \\
\end{aligned}
Now:
$$P(Z \le \frac 95) = \int_0^{9/5} f_Z(z)\,dz$$
(Thinking)
mathmari said:
Hey! :o
It is easy to arrive at...
$\displaystyle f_{Z} (x) = \begin{cases} x & \text{if}\ 0 \le x < 1\\ 2 - x & \text{if}\ 1 \le x \le 2\\ 0 & \text{otherwise}\ \end{cases}\ (1)$
... so that is...
$\displaystyle P \{Z < \frac{9}{5} \} = \int_{0}^{1} x\ d x + \int_{1}^{\frac{9}{5}} (2 - x)\ dx = \frac{1}{2} + \frac{24}{50} = \frac{49}{50}\ (2)$
Kind regards
$\chi$ $\sigma$
I like Serena said:
Hi! ;)
\begin{aligned}
&= \begin{cases}
\end{cases} \\
&= \begin{cases}
\end{cases} \\
&= \begin{cases}
\end{cases} \\
\end{aligned}
Now:
(Thinking)
Could you explain why the equality $$\int_0^z f_X(x)f_Y(z-x)\,dx = \begin{cases}
\end{cases} $$ stands?? Why do we have to take these cases?? (Wondering)
And also, do we replace at the integral $f_X(x)$ with $1$ using the formula $$f(x)=\left\{\begin{matrix}
\frac{1}{b-a} & , a \leq x\leq b\\
0 &, x<a \text{ or } x>b
\end{matrix}\right.$$ ?? (Wondering)
Your second question is the answer to the first one. (Wasntme)
Since $f_X$ and $f_Y$ are piece wise functions, we need to distinguish the cases where they are $0$ and non-zero.
That's why the integral needs to be split up into separate cases.
And that's why the bounds can be adjusted to only specify the bounds where $f_X$ respectively $f_Y$ are non-zero. The part where they are zero vanishes. (Mmm)
Ahaa..
At the formula $$f(x)=\left\{\begin{matrix}
\end{matrix}\right.$$ we take cases as for $x$, and the variable of $f$ is $x$.
But at the formula
\end{cases} $$ why do we take cases as for $z$ although the variable of $f_X$ is $x$?? (Wondering)
mathmari said:
Ahaa..
But at the formula
The range of $x$ in the integral is $[0,z]$.
If $0 \le z < 1$, then that implies that $0 \le x < 1$. Therefore $f_X(x) = 1$.
If $1 \le z \le 2$, then that implies that $0 \le x \le 2$.
However, we only have $f_X(x) = 1$ if $0 \le x \le 1$.
Therefore we need to limit the upper boundary to $1$ instead of $z$.
Then $f_X(x) = 1$ on the complete range of the integral.
(Wasntme)
(Wasntme)
Knowing that $$f_X(x) = \begin{cases}
1&\text{if } 0 \le x \le 1 \\
\end{cases}$$
we have the following:
$$f_Z(z)=\int_0^z f_X(x)f_Y(z-x)\,dx = \begin{cases}
\int_0^z f_X(x) \cdot f_Y(z-x)\,dx &\text{if } 0 \le z < 1 \\
\int_0^z f_X(x) \cdot f_Y(z-x)\,dx &\text{if } 1 \le z \le 2 \\
\end{cases} \\ = \begin{cases}
\int_0^1 f_X(x) \cdot f_Y(z-x)\,dx +\int_1^z f_X(x) \cdot f_Y(z-x)\,dx &\text{if } 1 \le z \le 2 \\
\int_0^1 1 \cdot f_Y(z-x)\,dx +\int_1^z 0 \cdot f_Y(z-x)\,dx &\text{if } 1 \le z \le 2 \\
\end{cases}$$
Then knowing that $$f_Y(x) = \begin{cases}
\end{cases}$$ and
$0 \le x \le 1 \Rightarrow -1 \le x \le 0 \Rightarrow z-1 \le z-x \le z$
\int_0^{z-1} 1 \cdot f_Y(z-x)\,dx + \int_{z-1}^1 1 \cdot f_Y(z-x)\,dx &\text{if } 1 \le z \le 2 \\
\int_0^z 1\,dx &\text{if } 0 \le z < 1 \\
\int_0^{z-1} 1 \cdot 0\,dx + \int_{z-1}^1 1 \cdot 1\,dx &\text{if } 1 \le z \le 2 \\
\int_{z-1}^1 1\,dx &\text{if } 1 \le z \le 2 \\
\end{cases} \Rightarrow \\ f_Z(z)= \begin{cases}
2-z\,dx &\text{if } 1 \le z \le 2 \\
\end{cases}$$
Therefore, $$P \left ( Z \leq \frac{9}{5} \right ) =\int_0^{\frac{9}{5}} f_Z(z)dz=\int_0^1 z dz+\int_1^{\frac{9}{5}} (2-z)dz= \left [ \frac{z^2}{2} \right ]_0^1+ \left [ 2z-\frac{z^2}{2} \right ]_1^{\frac{9}{5}}= \\ \frac{1}{2}+2\frac{9}{5}-\frac{1}{2} \left ( \frac{9}{5} \right )^2-2+\frac{1}{2}=\frac{18}{5}-\frac{81}{50}-1=\frac{180-81-50}{50}=\frac{49}{50}$$
Is this correct?? (Wondering)
I like Serena said:
Yep! (Nod)
Great! (flower) Thank you very much! (Yes)
I like Serena said:
(Except for $0≤x≤1⇒−1≤x≤0$. :eek:)[/color]
I forgot a minus sign.. (Lipssealed)
