Find radius and interval of convergence
3 replies · 3K views · last reply
isoman2kx
Σ √n X (x-1)^(n)
n=1
Ratio Test
let the series Σ An be a series with positive terms and lim as n ---> infinity is an+1 / an = finite number
a.
the series converges if r < 1
b.
the series diverges if r > 1 or r is infinite
c.
the test is inconclusive if r = 1.
Root Test
http://ltcconline.net/greenl/courses/107/Series/ratio.htm
So far I've tried the Ratio test (can't figure out how to not get an indeterminate form of anyhthing less than infinity multiplied by zero)
Then the root test, I'm not even sure where to begin once I divide the n's by n.
-travis
[tex]\frac{\sqrt{n+1}|x-1|^{n+1}}{\sqrt{n}|x-1|^n}= \sqrt{\frac{n+1}{n}}|x-1|= \sqrt{1+ \frac{1}{n}}|x-1|[/tex]
What is the limit of that as n goes to infinity?
just to help out say the limit as n->inf is = X. (hint as HallsofIvy pointed out, with his answer, plug in inf into n and rationalize what happens to the function )
Then to find the radius of convergence by the ratio test, X<1
that implies that -1<X<1. The you need to get X with a coefficient 1, if not then divide both side.
