Find Resistance Between A and B
  • Thread starter mmmboh
    Resistance
10 replies · 8K views · last reply
mmmboh
Circuit schematic of a resistor network between terminals A and B: 4Ω on the left upper branch, 2Ω on the right upper branch, a horizontal 4Ω bridging resistor in the middle, 2Ω on the lower left branch, and 4Ω on the lower right branch.
I have to find the input resistance; the resistance between A and B. I think it's Thevinin's theroem, however it is already an open circuit and there are no voltage sources and I can't combine the resistors to make an equivalent. So what do I doEdit: Am I suppose to remove the 4 ohm resistor connecting the two parallels, and find the equivalent resistance of those two and then add back the 4 as if it were in series?...so the final answer is 16/3 ohm? or is that wrong?
Place a voltage source across A-B and calculate the current that it would supply. The equivalent resistance will be the voltage divided by the current.
Ok, I tried it like you suggested vela. Made 3 Kirchhoff loops, put in an imaginary voltage source 10V, calculated the current to be 3.5A, so R should be 10/3.5...
That's the same answer I got.
I tried doing the loop thing, I don't think I did it right. Can you explain it please?
What loop thing? You won't get the answer with Kirchoff's laws alone. Instead, use Thevinin's theorem, pretending that there's a voltage V between A and B.
It would be better if you explain what you tried, so we can identify where you're having trouble. It's kind of hard to boil all of circuit analysis down to a forum post.
