Find T,N,B Vectors & Curvature of Curve x=-4ty=-t2z=-2t3 at t=1
  • Thread starter Thread starter FreedayFF
    Curvature
The problem involves finding the unit tangent, normal, and binormal vectors (T, N, B) as well as the curvature of the curve defined by the parametric equations x = -4t, y = -t², z = -2t³ at t = 1. The discussion centers around the calculations and methods for determining these vectors and the curvature.
  • Participants discuss their attempts to calculate the normal vector N and express confusion about discrepancies in their results. Some participants provide their calculations for T and N, while others question the methods used and the validity of their results.
There is an ongoing exploration of different methods to calculate the vectors and curvature, with some participants expressing uncertainty about their results. A few participants mention using software tools like Maple, which seem to yield different results from conventional methods. The discussion reflects a mix of approaches and interpretations without a clear consensus on the correct method.
Some participants note that they are unsure about the assumptions underlying their calculations and the conditions under which different methods yield varying results. There is also mention of a potential mistake in earlier calculations, which may have contributed to confusion.
FreedayFF
Find the unit tangent, normal and binormal vectors T,N,B , and the curvature of the curve
x=−4t y=−t2 z=−2t3 at t=1.
I found T=(-4/sqrt(56),-2/sqrt(56),-6/sqrt(56)) which is correct. But I keep getting N wrong? PLease help me, thank you!
Looks good as far as it goes. Hard to say what you are doing wrong unless you show us what you are doing to get N.
N = T'/|T'|
so the first term should be 0; but the webwork keeps denying that answer.
N = (0,-2/sqrt(148),-12/sqrt(148)) and that gives a wrong answer
Not 100% sure of this (im at work), but you get the train of thought:
Try the answers in bold
r(t) = (-4t)i + (-t^2)j + (-2*t^3)k
v(t) = r'(t) = (-4)i -(2*t)j - (6*t^2)k
||v(t)|| = sqrt(2*(4+t^2+9*t^4))
T(t) = v(t)/||v(t)|| =((-4)i + (-2*t)j + (-6t^2))/sqrt(2*(4+t^2+9*t^4))
Evaluate at t=1
T(1) = ((-4)i + (-2)j + (-6)k)/(6503/869) = 869*(-4i-2j-6k)/6503
N(t) = T'(t)/||T'(t)|| = diff(T,t)/length(diff(T,t))
N(t) = 0i - (2/3) j - (4*t)k
evaluate at t=1
N(1) = 0i - 2/3j -4k
B=T x N = [ 4*t^2, -16*t, 8/3]
at t=1
B(1) = 4i - 16j + 8/3k
I believe your answers are incorrect, as I have all T,B, curvature correct in the attached image above. Your T, however, has the same i value as mine, which is 0 and incorrect.
T=[-0.53454,-0.26727,-0.80181]
N=[0.81053,0.10665,-0.57592]
B=[0.23942,-0.95771,0.15962]
Maple rules.
Okay Maple rules do give correct answers. Thanks. But I don't understand why they would give different answers to the "conventional" methods. I'm confused about when to use Maple rules and when not?
I made a mistake earlier while using the conventional method. The correct way is:
N(t) = T'(t)/||T'(t)|| = (r'(t) x (r''(t) x r'(t)))/(||r'(t)||*||r''(t) x r'(t)||) = <304/(8*sqrt(157)*sqrt(14)), 40/(8*sqrt(157)*sqrt(14)), -216/(8*sqrt(157)*sqrt(14))>
DUH. It all checks out.
  • · Replies 22 ·
  • · Replies 17 ·
