Find the angle between 2 vectors
The discussion focuses on calculating the angle between two vectors, specifically vector a with magnitude 2 and vector b with magnitude √3. The participants analyze the expression |a - 2b|^2 using the Law of Cosines, ultimately determining that the angle θ between vectors a and b can be derived from the dot product. The correct formulation is |a - 2b|^2 = |a|^2 + |2b|^2 - 2|a||2b|cos(θ), emphasizing the need to correctly apply the Law of Cosines to find θ.
  • Understanding of vector magnitudes and directions
  • Familiarity with the Law of Cosines in vector form
  • Knowledge of dot product and its geometric interpretation
  • Ability to manipulate algebraic expressions involving trigonometric functions
  • Study the Law of Cosines in both triangle and vector contexts
  • Learn about vector dot products and their applications in finding angles
  • Explore vector addition and subtraction to understand resultant vectors
  • Practice solving problems involving angles between vectors using given magnitudes
Students studying linear algebra, mathematicians, and anyone interested in vector analysis and geometry.
Helly123
|a| = 2
|b| = ## \sqrt3##
|a - 2b| = 2
Angle between a and b
##\theta## is angle between a and b
So angle between a and -2b is 180-##\theta## [/B]
##|a-2b|^2## = |a|^2 + |2b|^2 -2|a||2b|cos(180-##\theta##)
##2^2## = 2^2 + (2##\sqrt3##)^2 -2(2)(2##\sqrt3##)( - 1)cos(##\theta##)
Then find the angle
What is wrong? Can you help me?
Helly123 said:
|a| = 2
|b| = ## \sqrt3##
|a - 2b| = 2
Then find the angle
Why bother finding the angle between ##\vec{a}## and ##-2 \vec{b}##? However, since you have found that angle, you must then use it correctly, not the way you have done it.
Helly123 said:
|a| = 2
|b| = ## \sqrt3##
|a - 2b| = 2
Then find the angle
What's wrong is that you have used the Law of Cosines on the wrong triangle. Instead of doing this, use the idea that ##|a - 2b|^2 = (a - 2b) \cdot (a - 2b)##, and expand this out. You will also need one of the definitions of the dot product -- the one that involves the angle and the magnitudes of the vectors.
But it still makes more sense to me. Because the |a| |b| and |a-2b| can be seen as triangle right? |a| is a length of vector a with magnitude 2 right?
Although, i find that expanding (a-2b)^2 also can be the way. Maybe if being elaborated, you mean that :
(a-2b)•(a-2b) = |a-2b|.|a-2b|cos0
Thus, |a-2b|^2 = (a-2b)•(a-2b)
Because i thought finding angle between ##\vec a## and ##\vec { -2b}## i can find angle between a and b. Since 180 - angle(a-2b) = angle(a+b) under the condition, if it's true that ##\vec b## has same degree with regards to x-axis as ##\vec {-2b}## just different direction going left or right and different lenght
I don't see how this works at all. Knowing the angle between ##\vec a - \vec {2b}## and either ##\vec a## or ##\vec b## doesn't help you find the angle between ##\vec a## and ##\vec b##.
You're given |a| and |b|, so if you can get ##a \cdot b##, you can find ##\theta##. If you do what I said, of expanding ##(a - 2b) \cdot (a - 2b)##, you will be able to solve for ##a \cdot b## in terms of everything else, and from that you'll be able to get ##\cos(\theta)## and hence ##\theta##.
I meant something like this
Can i say that |a+b|^2 = |a|^2 + |b|^2 - 2|a||b|cos##\theta##
|a-2b|^2 = |a|^2 + |2b|^2 - 2|a||2b|(-1)cos##\theta##
Helly123 said:
I meant something like this View attachment 224578
Sure, because here you're using the Law of Cosines.
This should work, now that I see your drawing, but for some reason, this equation gives a negative value for ##\cos(\theta)## while the way I did it gives a number that is equal in absolute value. I don't see why that's happening, though. In other words, if r and s are positive numbers, your way gives the cosine as -r/s and my way gives the cosine as r/s.
Yes. But not only negative. My way give wrong value for ##\theta##. It gives cos##\theta## = ##\frac{-12}{8\sqrt 3}##...
This simplifies to ##\cos(\theta) = \frac{-3}{2\sqrt 3} = \frac{-\sqrt 3} 2##. I get ##\cos(\theta) = \frac {\sqrt 3} 2##.
No, you cannot say that. The correct evaluation is ##|a+b|^2 = |a|^2+|b|^2 + 2 |a| |b| \cos \theta,## where ##\theta## is the angle between ##a## and ##b##. Note the + sign in front of the ##2 |a| |b| \cos \theta.## Similarly, ##|a-b|^2 = |a|^2+|b|^2 - 2 |a| |b| \cos \theta.##
Therefore, ##|a-2b|^2 = |a|^2 + |2b|^2 - 2 |a| |2b| \cos \theta##.
Why the law of cosinus is ##c^2 = a^2 + b^2 - 2 ab \cos \theta##
How can we get conclusion like that?
In the vector addition for the law of cosines, ## \vec{b}=\vec{a}+\vec{c} ## or ## \vec{a}=\vec{b}+\vec{c} ## is what the triangles look like if you make the triangle into a vector sum. The vectors get added by connecting tail to head. Either ## \vec{b} ## or ## \vec{a} ## winds up being the resultant. Thereby ## |\vec{c}|=|\vec{a}-\vec{b}| ##. ## \\ ## ( Note: If you want to find ## \vec{a}+\vec{b} ## , you need to pull ## \vec{a} ## and ## \vec{b} ## apart, so that their tails are not connected.).
|\mathbf{a} - 2 \mathbf{b}|^2 = (\mathbf{a} - 2 \mathbf{b}) \cdot (\mathbf{a} - 2 \mathbf{b})\\
= \mathbf{a} \cdot \mathbf{a} - 2 \mathbf{a} \cdot ( 2\mathbf{b} ) + (2 \mathbf{b}) \cdot (2 \mathbf{b})
By definition, for two vectors ##\mathbf{u}## and ##\mathbf{v}## their inner product is ##\mathbf{u} \cdot \mathbf{v} = |u| |v| \cos \theta##, where ##\theta## is the angle between the two vectors.
In vector addition for the law of cosines, we define c with a and b. So, it supposed to be ##\vec c = \vec a + \vec b## right?
a+ b is head of vec a meets tail of vec b right? Or, when
you said that ##\vec c = \vec a - \vec b##. Do you mean that is when head of vec a meets the tail of vec b?
When i examined it carefully. When i realized you substituted the ##\vec a ##. ##\vec {2b}## of #15 into |##\vec a##| |##\vec 2b##|cos##\theta## and resulted the formula in #11. It makes senses...
I think yes. Thanks
  • · Replies 26 ·
