Find the angle between two vectors
8 replies · 2K views · last reply
lwin
Can’t seems to find the "°"
Fx=Fcos”°”
Fy=Fsin”°”
Resultant = Squareroot(Sum of Fx)^2+(Sum of Fy)^2
Can’t seems to find the degree
  • Free-body diagram of a peg with three forces: 750 N at 41 degrees above the x-axis, 390 N at 35 degrees below the x-axis, and an unknown force P at angle theta below the negative y-axis, with x and y axes shown.
According to the diagram, there are 3 forces acting. What should you to do with them to get the resultant force?
Hint: Try to setup a system of two equations with two unknowns.
Already did that
These 2 equations are "written on" x & y axises
y axis:
750 cos(41) = 390 sin(35) + p cos(θ)
x axis:
>>you write this similarly<<P.S.
you may need to know that:
if,
cos(θ) = k
Then,
θ = arccos(k)
y axis:
x axis:
if,
cos(θ) = k
Then,
θ = arccos(k)
I will try it later, thanks :’)
lwin said:
Problem Statement: Can’t seems to find the "°"
Relevant Equations: Fx=Fcos”°”
Fy=Fsin”°”
Hi @lwin,
Welcome to Physics Forums.
In future, please make sure that the full problem is described in the Problem Statement section rather than the Attempt at Solution section.
Photos of a computer screen are not the best way include images. A better method would be to use a snipping tool to capture the relevant portion of the screen and then pasting the result into the post. Windows has a snipping tool odly enough called "Snipping Tool" :smile:
gneill said:
Hi @lwin,
Alright I will take note. It is my first time posting so do forgive me.
No worries. Again, welcome!
@lwin, only now I noticed that it was your first post - welcome to PF!
One more hint for you: when solving the two equations for ##P## and ##\theta##, this equation might come handy:
$$\cos^2 \theta + \sin^2 \theta = 1$$
