Find the Cartesian equation given the parametric equations
6 replies · 2K views · last reply
chwala
Find the cartesian equation given the parametric equations;
##x=\cos ^3t, y=\sin^3 t ##
hmmmmm nice one...boggled me a bit; was trying to figure out which trig identity and then alas it clicked :wink:
My take;
##x=(\cos t)^3 ## and ##y=(\sin t)^3##
##\sqrt[3] x=\cos t## and ##\sqrt[3] y=\sin t##
we know that
##\cos^2 t + \sin^2t=1##
therefore we shall have,
##x^{\frac{2}{3}} + y^{\frac{2}{3}}=1##
Any other way is highly appreciated...
anuttarasammyak said:
You should consider negative x y case.
I seem not to get you. Consider negative cases in what way?
I interpreted the equation as well as Wolfram do as below shown.
Wolfram Alpha screenshot plotting x^(2/3) + y^(2/3) = 1, showing a curve in the first quadrant from (0, 1) down to (1, 0), with x and y axes from 0 to 1.
Wolfram Alpha output for plot |x|^(2/3)+|y|^(2/3)=1, showing a four-cusped astroid-like curve centered at the origin, crossing the axes at x and y = plus or minus 1.
As for your
[tex]\sqrt[3] x=\cos t ,\sqrt[3] y=\sin t[/tex]
I am not sure whether [tex]\sqrt[3]{-1}=-1[/tex] is a conventional expression. Say it is so,
[tex](-1)^{2/6}=1^{1/6}=1 \neq (-1)^{1/3}[/tex]
That seems inconvenient.
Sure it is. A negative real number has a real and negative root, plus a couple complex roots.
If we allow negative x for ##x^{m/n}##
[tex]x^{m/n}=x^{2m/2n}=(x^2)^{m/2n}=(|x|^2)^{m/2n}=|x|^{m/n}[/tex]
for an example
[tex]\sqrt[n]{-1}=\sqrt[n]{1}=1[/tex]
which is a false statement. So I think we had better use ##x^{m/n}## for only positive x.
[EDIT] In order the defnition of imaginary number unit,
[tex]\sqrt{-1}=i[/tex], remains sound, we should just watch as it is and never apply the procedures above.
I don't believe there is any problem with ##\sqrt[3]{-1} = (-1)^{1/3}##, both of which are equal to -1.
However, when you start manipulating the exponent, using the properties of fractional exponents, then I agree that you run into trouble when the base is negative.
Having thought about things a bit longer, @anuttarasammyak, I agree with what you are saying. The parametric equations ##x = \cos^3(t)## and ##y = \sin^3(t)## agree with the resulting equation that @chwala got: ##x^{2/3} + y^{2/3} = 1## only when both x and y are positive. For negative values of x or y, which map to values of t in the parametric equations, you run into problems of inconsistency in the non-parametric equation.
