1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Find the induced current
  1. Nov 20, 2016 #1
    A coil with 140 turns, a radius of 5.2 cm, and a resistance of 11.0 Ω surrounds a solenoid with 200 turns/cm and a radius of 4.5 cm. The current in the solenoid changes at a constant rate from 0 A to 2.0 A in 0.10 s. Calculate the magnitude and direction of the induced current in the 140-coil.
    2. Relevant equations
    EMF = -N (dφ/dt)
    3. The attempt at a solution
    Iind = EMF/ R of the coil, due to Ohm's law.
    So I know that I should find the EMF of the coil using
    EMF = -N (dφ/dt) = -N (A) (dB/ dt)
    I should find dB/dt, but I'm not totally sure how. I think I could use the magnetic field formula for a ring at the center maybe B= (μ0I) / (2 rcoil) , where the current, I , is changing due to the solenoid?
  3. Nov 21, 2016 #2
    I know many will find this a stupid question but is the coil with the 140 turns forming a close loop between its two ends? Can you provide some sort of schematic to let us see how exactly the two coils are.
    Anyway if the coils configuration is as I think it is, then you should indeed try to find dB/dt (have in mind that as area A you should take the area of the solenoid(the coil with the 200turns/cm) not the area of the coil with the radius of 5.2cm). I believe you should use the formula ##B=\mu_0I\frac{n}{L}## where ##\frac{n}{L}=200## .
  4. Nov 21, 2016 #3
    Yes, I forgot to post the picture.
  5. Nov 21, 2016 #4
    Great I got the answer (see below). Could you clarify though, why I would use the area of the solenoid versus the single coil?
    Bsolenoid = μ0 I (N/L)
    dB/dt = μ0(dI/dt)(N/L)
    EMF = Ncoil (dB/dt) Asolenoid = Ncoil0(dI/dt)(N/L) ] A solenoid = .44768V
    Iind = .44768V/ 11Ω = .04069A
  6. Nov 21, 2016 #5
    Because that's exactly the area where the magnetic field varies with time. Outside that area there is magnetic field (which is caused by the induced current on the 140 turn coil) but since the induced current is constant that magnetic field is constant too.
  7. Nov 21, 2016 #6
    Ah, got it. Thanks!
Have something to add?
Draft saved Draft deleted
