Find the mass of a piece of a cylinder
  • Thread starter Thread starter Feodalherren
    Cylinder Mass
The discussion revolves around calculating the mass of a cylindrical piece defined by the equation x² + y² = 1, situated in the first octant, above z=0, and below z=1-x, with a density function D=x. The initial integral setup was incorrect for finding the mass of a surface rather than a solid, leading to confusion. The correct approach involves using a surface integral, resulting in the mass being calculated as 1 - π/4. The problem highlights the distinction between solid and surface mass calculations in multivariable calculus.
  • Understanding of multivariable calculus concepts, particularly surface integrals.
  • Familiarity with cylindrical coordinates and their application in integration.
  • Knowledge of density functions and their role in mass calculations.
  • Experience with setting up and evaluating triple integrals.
  • Study surface integrals in multivariable calculus.
  • Learn about cylindrical coordinates and their integration techniques.
  • Explore examples of mass calculations for thin sheets in engineering contexts.
  • Review the application of density functions in physical problems.
Students in calculus courses, particularly those studying multivariable calculus, engineers dealing with mass and density calculations, and anyone interested in the application of integrals in physical contexts.
Feodalherren
Find the mass of the piece of a cylinder x^2 + y^2 =1 that lies in the first octant above z=0 and below z=1-x.
The density is D=x.
I set up this integral:
\int^{\pi/2}_{0} \int^{1}_{0} \int^{1-rcos\theta}_{0} r^{2}cos\theta dz dr d\theta
Which ends up coming out as \frac{1}{3} - \frac{\pi}{16}
The correct answer is 1- \frac{\pi}{4}
Nevermind I figured it out. They only wanted the "shell" mass. I had to do a surface integral.
The density is D=x.
Do you recall the discussion in your previous post about the mass of a funnel? There was confusion whether your problem was to give the mass of a solid or a surface. You have the same issue in this problem. You have worked it as the mass of a solid piece of a cylinder in the first octant under that plane. Are you sure you aren't supposed to be thinking of a thin metal sheet forming just the curved surface of that cylinder? In that case you would want a surface integral. It would help if you would state the problem completely and exactly as it appears in your book. My guess it that it is supposed to be a surface integral.
[Edit] I see you figured it out while I was typing my response.
This question actually came off an old quiz and it was stated on it exactly as I typed it. It seems counter intuitive to me anyway. Isn't the surface just infinitely thin and thus without mass? This whole idea seems weird to me. How could a surface possibly have mass?
It can be a useful approximation for some physical situations when one dimension is negligible in comparison to the other two.
How do you mean? Could you give me an example of a physical interpretation? One that's applicable to engineering would be awesome :).
Things that are thin, like a sheet of paper, a steel plate, gold foil, etc.
Hmm yeah ok fair enough. Thanks.
  • · Replies 19 ·
  • · Replies 20 ·
