Find the Net Torque on Pulley with Masses M1 and M2
The discussion revolves around calculating the net torque on a pulley system involving two masses, M1 and M2, connected by a string. The problem assumes no friction and neglects the mass of the string, prompting participants to explore different methods for determining the net torque about the center of mass of the pulley.
  • Mixed
  • Participants discuss two different methods for calculating torque, one based on external forces and the other on tensions in the string. There are questions regarding the correctness of each method and the assumptions made about the forces acting on the pulley.
Some participants have provided guidance on the need for additional equations to relate the tensions and angular acceleration of the pulley. There is ongoing exploration of the implications of using different approaches, with some participants questioning the definitions and assumptions underlying the calculations.
There is a noted ambiguity regarding the definition of external forces and their role in calculating torque, as well as the relationship between the tensions in the string and the moment of inertia of the pulley. Participants are also considering the implications of analyzing the system as a whole versus focusing on the pulley alone.
Gravitino
Two blocks of masses [tex]M_1[/tex] and [tex]M_2[/tex] passes through a pulley (See the Fig. attached.). Assuming the friction between block and the incline is zero, and neglecting the mass of string find the net torque about the center of mass of the pulley.
I solved this problem with two different ways. The answers are different. Please, let me know, where I am wrong.
1) [tex]\tau=\left(M_1-M_2\sin\theta\right)gR[/tex] because the net torque is due to external forces.
2) On the other hand, [tex]\tau=\left(T_1-T_2\right)R[/tex]. And the tensions [tex]T_1[/tex] and [tex]T_2[/tex] are found from
[tex]M_1g-T_1=M_1a[/tex]
[tex]-M_2\sin\theta g+T_2=-M_2a[/tex]
The solution gives different answer. In the case, [tex]a=0[/tex], the two solution matches.
Which one is correct?
The second one is correct. So far you only have two equations in three unknowns, but there is also a third equation involving the rotational motion of the pulley, which also involves the torque (hence T1 and T2) and relates it to the angular acceleration of the pulley (which is related to a).
Net torque on what? :wink:
That's the net torque on the pulley. You need to apply Newton's 2nd law here as well.
Looks like you have a sign problem between these equations.
What was your solution using method 1? You found the net torque, but didn't continue. (Hint: Too hard!)
Method 2 will give you the answer (if you correct the signs) and continue. That's the way to go.
(Dick's way ahead of me!)
Thanks. But i have still doubt. The first solution states that the net torque about the center of pulley, is just due to the external forces. They are the one which rotate the pulley. And Obviously, [tex]\tau=F_{net}R[/tex]. And external forces are just gravity.
Net torque about center of pulley, you are right. For the first method, as i explained above, [tex]\tau=F_{net}R[/tex] and [tex]F_{net}=M_1g-M_2g\sin\theta[/tex].
In the second one,
[tex]M_1\sin\theta g-T_1=M_1a[/tex]
[tex]-M_2\sin\theta g+T_2=M_2a[/tex]
and the answers stiull do not match.
The 'external forces' aren't the gravitational forces, they are the tensions in the string. The tensions in the strings will depend on such things as the moment of inertia of the pulley. Pretend there is only the hanging mass. If the mass is heavy and the pulley is light, the downward acceleration will be almost g and the tension in the string will be much less than mg. If the mass is light and the pulley is heavy, then acceleration down will be much less than g and the tension in the string will be almost mg.
The net torque on the entire system--pulley and the two masses--is just due to external forces acting on the system.
No. The tension forces act on the pulley to rotate it, not the weight of the masses. If you analyze the pulley, the tension forces are external to it. But if you analyze the entire system as a whole (not recommended), then you can say that the external forces are the weights of the masses.
The problem with method 1: You think you're finding the torque on the pulley, but you're not; you're finding the torque on the entire system. (That's why I asked: Torque on what?)
Thanks! I got it!
Thanks! :approve:
  • · Replies 30 ·
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 34 ·
