Find the Perfect Drain Size for Your Cylindrical Tank | Flow Physics Assistance
  • Thread starter Thread starter wat
    Flow Physics
The discussion focuses on determining the appropriate drain size for a horizontal cylindrical tank with a 2-meter inner diameter and a capacity of 50 m³, which is 60% full of liquid and under 3 bar pressure. To achieve a flow rate of 2.8 m³/h without pumps, the calculated drain diameter is approximately 0.2 mm, using a conservative discharge coefficient of 0.85. The pressure inside the tank translates to an effective head of about 39 meters initially, which decreases as the tank empties.
  • Understanding of fluid dynamics principles
  • Familiarity with pressure calculations in cylindrical tanks
  • Knowledge of discharge coefficients in fluid flow
  • Basic skills in using online fluid calculation tools
  • Research "Fluid dynamics in cylindrical tanks" for deeper insights
  • Learn about "Discharge coefficients and their impact on flow rates"
  • Explore "Viscosity effects on fluid flow in pipes and tanks"
  • Investigate "Using online calculators for fluid flow analysis"
Engineers, fluid mechanics students, and professionals involved in tank design and fluid flow optimization will benefit from this discussion.
wat
i need your urgent help in the following :
I have a cylindrical tank :
- inner diameter is 2 m
- capacity 50 m3
- height over ground 0.5 m (50 cm) from ground to tank bottom
- the tank is 60% full of liqued and 40% gas , the pressure inside
the tank is 3 bar :
What is the drain size (diameter) that allow to get 2.8 m3/h of the liquid , without using any pumps , just by the pressure force inside the tank ?
and thanks for your help
:cry: :confused:
That is a funny tank, in practice. (16 m height / 2m dia.) Is it horizontal or vertical?
Just go to the link below and do some trials and error.
http://www.efunda.com/formulae/fluids/draining_tank.cfm#calc
Consider 3 bar as 30 meters head approximately. 60% liquid adds about 9 meters and initially the head will be 39 meters. As the tank gets emptied, the head will be 30 meters. The average of these two flow readings gives you the average flowrate.
The diameter is approximately 0.2mm
Use a rather conservative discharge coefficient of 0.85
flow
many thanks for reply
the tank is horizontal , attached drawing is cross section in tank
and what is the effect of liquid viscosity ?
thanks again
  • · Replies 18 ·
13K
