Find the time interval between the above two events.
The discussion revolves around calculating the time interval between two events involving a Canadian helicopter and a foreign fishing submarine. The helicopter fires a laser beam at two different angles, initially at 10° and later at 30° below the horizontal, requiring the use of Snell's law to determine the angles of refraction. Participants suggest using right triangles to find the horizontal distances between the helicopter and submarine at both firing instances. By calculating these distances and considering the velocities of both the helicopter and submarine, the time interval can be derived. The conversation emphasizes the importance of understanding the geometry of the situation to solve for the time difference effectively.
7even
A foreign fishing submarine moves straight north through Canadian waters at a constant velocity of 12 m/s and a constant depth of 150m below the surface. A Canadian helicopter is in pursuit, flying in exactly the same direction at a constant velocity of 52 m/s and a constant altitude of 550m above the surface. The helicopter, lightly armed, shoots a narrow laser beam which enters the water and strikes the submarine. At one instant, the laser beam leaving the helicopter is directed at an angle of 10° below the horizontal to hit the target. At a later time, the beam has to be tilted down to 30° below the horizontal to maintain contact. Given that the index of refraction is 1.00 for air and 1.33 for water, find the time interval between the above events.
Possible Answers;
a) 33.3
b) 55.1
c) 68.9
d) 46.7
e) 78
n1xsin∅1 = n2xsin∅2
I found the two refractive angles;
1xsin10° = 1.33xsin∅1
∅1 = 7.5°
1xsin30° = 1.33xsin∅2
∅2 = 22.08°
After that, I'm stuck. I have no idea how to use that to find the time interval between each degree.
Hello 7even. Welcome to PF!
In Snell's law are the angles measured from the surface or from the normal to the surface?
From the horizontal, so yes, the surface!
I see, so those angles should be changed from 10 to 80 and 30 to 60.
Therefore ∅1 = 47.77° and ∅2=40.63
Yes. good. Consider the first firing of the laser. Can you figure out the horizontal distance between the helicopter and submarine at this instant?
Create a right angle triangle; use the vertical length between the submarine and the helicopter and solve for the horizontal distance.
Therefore, tan10°=700m/x ... x = 3969.9m
No. You're going to need two right triangles. One for the helicopter and one for the submarine.
I see. For the first instant;
tan10°=550m/x ... x = 3,119.2m
tan47.77°=x/150m ... x = 165.25m
So you can figure out the total horizontal distance between the two at the first firing. Repeat for the second firing and see if you can use these distances to determine the time.
Oh I get it, thanks so much for the help!
7even said:
I take the the distances for the first instant and divide each by it's own velocity.
I don't understand why you would do that.
If you were on the submarine how far away horizontally from you was the helicopter at the first firing? How far away horizontally was the helicopter away from you at the second firing? Thus, conclude how much closer the helicopter got (horizontally) to the submarine between the two firings.
17K
14K
