Find the unique solution to the initial value problem
The initial value problem requires finding a unique solution based on the provided equation. The constant has been determined as y(0) = 1, which is confirmed to be correct. However, there is uncertainty regarding how to derive the function g(t). It is suggested that additional information may be necessary to solve for g(t). The approach of taking the derivative of the solution and substituting it into the differential equation is recommended for further progress.
Colts
The unique solution to the initial value problem
is http://webwork.usi.edu/webwork2_files/tmp/equations/ed/12ad7dca5df62ed3b18f5fbf8c6e871.png
Determine the constant
and the function
Not sure for the second part.
I got the constant y(0)= 1 and know that is correct. I can not figure out how to get g(t). I feel like you need more information on the original problem.
Take the derivative of the solution and substitute into the diff. equation.
Thank you
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
