Find the Voltage in the parallel resistor-capacitor circuit
31 replies · 5K views
Helly123
C1 = 4 micro F
C2 = 8 mF
R1 = 4 ohm
R2 = 8 ohm
V = 12
Questions :
1) Find current I when S not closed
2) find Vb, when Vc is 0
3) find Vd, when Vc is 0
4) total charge move from B to D
Vf - Vi = F.d/q
(not sure this below is useful equations)
I = E/Z
E = E resistor = E capacitor
I total = Iresistor + Icapacitor
z = 1/(1/Zr + 1/Zc)
1) I = V/R = 12/12 = 1A. (I wonder if the capacitor will affect current? since in Q = CV, there is no current as in V= IR)
2) what makes the Vc is 0? I thought that Vb = 12 V - ## V_{resistor2ohm}## Is there any relation with Vc?
3) same as 2)
4) I thought maybe the charge referred is the charge in this equations (Vf - Vi) = F.d/q
any help is appreciated :)
1) Do you know how a capacitor is made? If not, I suggest that you look it up. How much direct current can flow across a capacitor?
3) same as 2)
The intent here is to assign an arbitrary voltage reference. In a circuit you can measure voltage differences. If you pick one point in the circuit as the reference point and call the voltage there ##0##, then you can express the voltage at other points relative to the reference point.
When the switch is closed, what will be the voltage at D? What will be the voltage across each capacitor? Given the equation ##Q=CV##, how much charge will accumulate on each of the capacitors? What will be the sign of the charge on the capacitor plate of C1 that is connected to D? How about the sign of the charge on the capacitor plate of C2 that is connected to D?
You are correct but you need to understand that ALL voltages are measured relative to some point even if we are lazy and don't always explicitly say so.
When they say Vc=0 all they are doing is asking you to calculate Vb relative to Vc rather than relative to some other node. In this case Vc is connected to the -ve terminal of the battery so it's reasonable to define Vc = 0V.
When you wrote "12V" above you were probably referring to the voltage at the +ve terminal of the battery (or Va) relative to the -ve terminal (Vc).
When you wrote "Vresistor2ohm" you were probably referring to the voltage drop across R2. In other words the voltage of one end of R2 relative to the other end of R2.[/QUOTE]
Helly123 said:
C1 = 4 micro F
C2 = 8 mF
Is C2 really 8 millifarads rather than 8 microfarads? If the intent was to produce an "interesting" capacitive voltage divider, then choosing one to be on the order of 1000 X the other seems a bit suspect to me. Just checking :smile:
Microfarads Sir :)
i still don't get it? Capacitor allows AC block DC, doesn't it?
is it 8V if referred to point A, and 4V if referred to point C ?
The voltage across C2 is 12 V, in C1 also 12V
But i still don't get it, how to find current in C1 and C2
i think, yes :)
Yes, is it 12V?
That is correct. So zero direct current flows across a capacitor, in answer to your question, "I wonder if the capacitor will affect current?"
Capacitors can cause transient currents in DC circuits, though, and that is point of question 4). How much charge flows from point B to point D?
That is not what I meant. If you pick C as your voltage reference point and set ##V_C = 0##, then at point A, the voltage ##V_A = V_A-V_C=12V## because the voltage difference from C to A is 12V. What would be ##V_B##, the voltage at B, given that ##V_C## is zero?
For this problem, you only need to worry about the voltages across the capacitors when the switch is closed. If the switch is closed, what is the voltage difference between B and D? What does that tell you about the voltages across the capacitors?
Helly123 said:
Yes, is it 12V?
No the voltage drop across R2 is not 12V.
Correct. They ask for Vb relative to Vc so the answer is 4V.
That's not correct. The total voltage across C1 and C2 added together must be the same as the battery voltage and the same as the voltage across R1 and R2 added together. That's because these three are all connected between the same nodes A and C.
Think how is a capacitor made. There are two plates with a gap between that is sometimes filled with air. No current ever flows "through" a capacitor. However when a voltage is applied to a capacitor electrons flow onto one plate and different electrons flow out of the other until the voltage across the capacitor matches the applied voltage and the flow of electrons stops. So it looks like current is flowing but only for a short period or while the applied voltage is changing (eg AC). In this circuit the voltage on the capacitor will eventually stabilise to a DC value ( there are no AC sources) so eventually the current in the capacitors will be zero.
To answer q4 I believe you need to assume the following steps occur...
1) the capacitors start off discharged, the switch is open and the battery is disconnected.
2) the battery is then connected and the capacitors charge so a voltage appears on D and another voltage, possibly different, appears on B.
3) the switch is made/closed connecting B and D.
4) if the voltage on B and D calculated in step 2 was different then current would flow until it was the same. They are asking how much charge flows.
Start by working out the voltages at step 2. You have already calculated Vb so just need to calculate Vd.
i still don't get it. Why refers to Va become 4V. I thought that the voltage "remains" after used at point C is 4V. So the point B is 4V
##V_B = V_B
-V_ C= 4V## because Vb = 4V? Vb = 4V because the V remains after used in C is 4V.
I think we missunderstand each other.
With the switch open..
Vc = 0V
Va = 12V with respect to Vc
Vb = 4V with respect to Vc
Vb = -8V with respect to Va
When the switch is made/closed the voltage Vb may change briefly but it will quickly return to the same value I have listed above.
Helly123 said:
##V_B = V_B
VB = VB - VC
Doesn't make sense. You should use the double subscript notation...
VBC = VB - VC
Makes sense.
VBC is the voltage at node B relative to node C. This is the voltage you would measure if you connected a volt meter with the black lead on node C and the red lead on node B.
More help...
With the switch open...
The current through the resistors is 1A so VBC = 4V.
How to work out VDC... If the capacitors start off discharged then when the battery is connected they will quickly charge up. The charge that flows is the same for both capacitors because they are in series.
The general equation is Q=CV. If the charge is the same you can write...
C1* VDC = C2* VAD
You also know that..
VDC + VAD = 12V
If you solve these equations you get..
VDC = 8V
So with the switch open there is 4 volts across the switch.
CWatters said:
More help...
Amazing!
btw, do you mean when the switch closed there is 4V across B-D (switch) ?
the voltage flow from D to B is 4V (from D to B or B to D? but the ##V_D## = 8V, and ##V_B## = 4V, so from D to B ?)
the C1 and C2 is parallel now (when switch made) ? before it was series
so C total = 12 microFarads
Q flow from D to B = 48 microC = 4.8 ##10^{-5}## C?
Helly123 said:
Amazing!
No I mean when it's open. A closed/made switch had close to zero resistance so it cannot have a voltage across it or there would be a huge current flow.
I don't understand what you are saying.
Q flow from D to B = 48 microC = 4.8 10−510−510^{-5} C?
That is the answer I got...
The voltage across C1 changes from 8V to 4V. Q= 4*4*10-6 = 16*10-6C
The voltage across C2 changes from 4V to 8V. Q= 4*8*10-6 = 32*10-6 C
Both lots of charge flow through the switch so the total charge is 48*10-6C from D to B
I made this graph to show how Vd and Vb change.. Both voltages are with respect to Vc.
Charges flow from D to B. But, the question asked is from B to D. How is it?
Ok so I think the answer should be -48*10-6C.
I thought so at first . But, the answer is 48*10-6C. Lol
How to know that both charges flow through switch?
The voltage at C1 going to negative pole, but instead the charges go to switch?
CWatters said:
I will try and post a diagram.
yes please
Two diagrams. First shows the direction of current flow when a capacitor is charging or discharging...
Second diagram shows which capacitor is charging and which is discharging in your circuit...
if the voltage in C1 going through the switch, how about the voltage in D to C nodes?
the voltage in D to C nodes is 4V, the voltage still going circle in the circuit, but causes charges to move in the switch is that it? is that the voltage in D to C the same as D to B, because D-C and D-B parallel?
charges in C1 and C2 going through the switch (D to B) does it also go to D to C to A ?
Helly123 said:
if the voltage in C1 going through the switch, how about the voltage in D to C nodes? the voltage in D to C nodes is 4V, the voltage still going circle in the circuit, but causes charges to move in the switch is that it? is that the voltage in D to C the same as D to B, because D-C and D-B parallel?
I do not understand your question. In some places you say "voltage" when you mean "current"?
Please see the graph in #21.
1) With switch open..
The voltage on node D (with respect to C) = 8V.
The voltage on node B (with respect to C) = 4V.
2) When the switch is closed...
Node D is connected to node B. This means node D and B must have the same voltage. How do we decide if this is 8V or 4V? I will explain how..The voltage on node D cannot change instantly because of the capacitors...
Q=CV
differentiate
dQ/dt = C dV/dt
dV/dt cannot be very large because it would need a very large current (dQ/dt).
If the voltage on node D cannot change quickly then the voltage on node B must change because they are connected by the switch. So what happens is the voltage on node B shoots up from 4V to 8V. So now both node D and B become 8V. This is shown in the middle of the graph.
3) After that the resistors keep trying to "pull" the voltage on node D/B from 8V back down to 4V. This is the curved part of the graph in #21.
During the curved part of the graph current flows like this..
4) After some time the nodes D and B reach 4V and the two current shown stop flowing.
