Helly123
- 581
- 20
cos 2theta = costheta^2 - sintheta^2
cos2theta = 1
2theta = 0, 2phi
but i get wrong answer.. how is it?
Helly123 said:Homework Statement
cos2theta = 1
2theta = 0, 2phi
oh.. cos 2 theta = root 2 / 2Ray Vickson said:Well, given your values for ##\sin \theta## and ##\cos \theta## you should NOT get ##\cos 2 \theta = 1##. Check your algebra.
No, with cos +ve and sin -ve, the angle must be in the 4th quadrant. All silly tom cats. (A calculator will give you different angles.)phinds said:You get the "wrong" answer because the problem posits an impossible condition. Just use arccos and arcsin and you'll see they are talking about two different angles so it can't be right to call them both the same. For that matter, you don't even have to do any math; the signs alone tell you the angles are different.
Yes, I had already deleted my post before you posted thismjc123 said:No, with cos +ve and sin -ve, the angle must be in the 4th quadrant. All silly tom cats. (A calculator will give you different angles.)
θ = 2π - π/8 = 15π/8, and 2θ = 15π/4 (note the question asked for the answer as a multiple of π, not in degrees).
mjc123 said:π
Helly123 said:But the answer also 15/4 pi.. Which is 337.5 degree
the key answer it is. the 2 theta allowed to be bigger than 2 pi. just theta < 2piRay Vickson said:No, it isn't. ##2 \pi \leftrightarrow 360^o##, and ##15/4> 3> 2##, so ##15/4 \pi ## is a lot bigger than ##360^0##.
Helly123 said:no
As Ray said, that's not true. After all, (15/4)π ≠ 337.5° .Helly123 said:But the answer also 15/4 pi.. Which is 337.5 degree
You do know that there is a difference between "pie" and "pi" with the latter being the name of a Greek letter, right?MidgetDwarf said:But the restrictions say theta is defined on [0,2pie)?
Hence, 2theta=-pie/4.
From our restriction, this -pie/4 should be equal to 7pie/4 (sin is negative and cos is positive/ IV Quadrant).
Therefore 2theta=7pie/4
theta=7pie/8
Mark44 said:You do know that there is a difference between "pie" and "pi" with the latter being the name of a Greek letter, right?
The restriction applies to θ, not 2θ. It is also θ that must be in the fourth quadrant, therefore θ = 7π/8 is not acceptableMidgetDwarf said:But the restrictions say theta is defined on [0,2pie)?
theta=7pie/8
The restriction applies to theta, but cos(2θ) is positive and sin(2θ) is negative, therefore 2θ is in the fourth quadrant or 2pi more. And the problem asks 2θ.mjc123 said:The restriction applies to θ, not 2θ. It is also θ that must be in the fourth quadrant, therefore θ = 7π/8 is not acceptable
@mjc123 2 θ = is 45 degrees, theta = 22.5 degreesmjc123 said:π
From the magnitudes of cosθ and sinθ, the basic angle is 22.5° (π/8). (If you have to do this without a calculator, from the magnitude of cos 2θ, 2θ = 45°.) However, since cosθ is positive and sinθ is negative, θ must be in the 4th quadrant, i.e. between 3π/2 and 2π.Helly123 said:@mjc123 why θ = 2π - π/8 = 15π/8, and 2θ = 15π/4 ?
Why you substract π/8 from 2π?
I assume you mean "2 theta in quadrant 4 is 360-45". You can't use this because (for the millionth time) θ must be in the 4th quadrant. So 2θ must be between 3π and 4π.Helly123 said:Why can't i use directly 45degrees, so theta in quadrant 4 is 360-45 = 315 degrees
Since 315 and 675 have same cos value, why the answer is 675?
Haha yes. Thanksmjc123 said:From the magnitudes of cosθ and sinθ, the basic angle is 22.5° (π/8). (If you have to do this without a calculator, from the magnitude of cos 2θ, 2θ = 45°.) However, since cosθ is positive and sinθ is negative, θ must be in the 4th quadrant, i.e. between 3π/2 and 2π.
At PF we endeavor to maintain a high-quality site for the pursuit of science and mathematics, one aspect of which is to not conflate the number ##\pi## (or pi) with the dessert whose name is pronounced the same. I am aware that you have a strong knowledge of mathematics, but because you wrote "pie" six times in your post, I believed that this deserved comment and was relevant to the discussion.MidgetDwarf said:You do know that making a post within a topic, that is not relevant to the discussion is considered trolling?
As a mentor, I am very familiar with the forum rules. Hijacking a thread is a violation, but comments that relate directly to posts in the thread are neither off-topic nor hijacks.MidgetDwarf said:That is a violation of PF rules of conduct.
You can reduce those fractions. 45/36 = 5/4, etc., and it's pi, not phi.Helly123 said:If i used: sin2x = 2sinx cos x
Sin 2x = ## \frac{ -\sqrt2}{2}##
So 2x = 45/36 phi, 63/36 phi?
X = 45/72 phi or x = 63/72 phi
While x must on 4th quadrant..
Both x above not on 4th Q ..
What's wrong ?
What's wrong ?
Those actually should written be something likeHelly123 said:X (theta) must be on 4 Quadrant, so 2x must on 8 quadrants, 540<2x<=720
X 1=5/4 π
X2 = 7/4 π
Both added 2π to get x at 8 quadrants
X1 = 13/4 π
X2 = 15/4 π
Both satisfied the domain
How to decide which one is the answer?
