How Can Exponential Decay Reveal Initial Temperature?
4 replies · 2K views · last reply
Boba Fet
Suppose that you take a thermometer outside where it is 100°.
T(5min)=80° T(15min)=90°
What is the initial temp of the thermometer?
Given equation
dT/d t= k(T-Te)
Derived Equation
⌠(T-Te)^-1 (dT/dt)dt =⌠ kdt
ln(T-Te)=kt + c
T=ce^kt + Te
so i basically got the answer by knowing c must be negative and that when i use a square root on the magnitude of c i through out the positive value.
Wolfram Alpha
my real question is how can this become -3 ln(-20/x) +ln(-10/x) becomes -2ln(-(1/x)) -ln(800)?
Attempt to find C
1) 80=ce^k5 +100 ---- -20=ce^k5 ----- -20/c=e^k5 ------ ln(-20/c)=k5 ----- -3ln(-20/c)=-k15
2) 90=ce^k15 +100 ---- -10=ce^k15 ----- -10/c=e^k15 ------ ln(-10/c)=k15
becomes
ln(-10/c) - 3ln(-20/c) ----- ln((-10/c) x (c^3 / -8000)) -------- ln(c^2/800) ---- 2ln(c) -ln(800)=0
ln(c)=(1/2)ln(800)
c= +/- sqrt(800)
my real question is how can this[?] become -3 ln(-20/x) +ln(-10/x) becomes -2ln(-(1/x)) -ln(800)?
Are you saying that the expression:
##-3\ln\frac{-20}{x} + \ln \frac{-10}{x} = -2\ln\frac{-1}{x} - \ln 800## ... is not true?
... or you don't know how to get there from
T=ce^kt + Te
... which I am reading as ##T(t)=Ce^{kt} + T_e##?
The rest of your post appears to show you doing the calculation (though you need to say what finding "C" does for you.)
Do you know the relationship between the initial temperature and C?
Boba Fet said:
yes i don't know how to get there
− 3 ln − 20 x + ln − 10 x = − 2 ln − 1 x − ln 800 −3ln⁡−20x+ln⁡−10x=−2ln⁡−1x−ln⁡800
... that last bit does not make sense.
Off post #1, the way to understand how to get "there" must start from knowing what "x" stands for.
However, if you can find the initial temperature without going "there", then why bother?
Your solution to the differential equation should read:$$(T_e-T)=(T_e-T_0)e^{-kt}$$
So, $$20=(T_e-T_0)e^{-5k}\tag{1}$$
$$10=(T_e-T_0)e^{-15k}\tag{2}$$If you cube Eqn. 1, you get:$$8000=(T_e-T_0)^3e^{-15k}\tag{3}$$
What do you get if you divide Eqn. 3 by Eqn. 2?
