Find total E of muon using time dilation
To find the total energy of the Ω- particle using time dilation, the proper time (t0) and lab frame time (t) must be distinguished. The rest energy is given as 1672 MeV, and the particle's mean lifetime is 8.2 x 10^-11 seconds. The track length of 24 mm provides the distance traveled, which can be used to derive the velocity (v) by setting up the equation distance = speed × time. The relationship t = t0√(1 - (v/c)²) is crucial for calculating the lab frame time. Once v is determined, it can be substituted back into the energy equation to find the total energy of the particle.
oddjobmj
An Ω- particle has rest energy 1672 MeV and mean lifetime 8.2*1011 s. It is created and decays in a particle track detector and leaves a track 24 mm long. What is the total energy of the  particle?
E=\frac{mc^2}{\sqrt{1-(\frac{v}{c})^2}}
t=t0\sqrt{1-(\frac{v}{c})^2}
Rest E=mc2
Because Rest E=mc2 I know that:
E=\frac{1672 MeV}{\sqrt{1-(\frac{v}{c})^2}}
What I need to do now is solve for v using the given time and distance (.024 meters). The time is measured in the particle's proper frame so:
t=(8.2*1011 seconds)\sqrt{1-(\frac{v}{c})^2}
Of course, this contains v itself. What am I missing?
Thank you!
I am missing what you do with the track length...
Set up an equation for distance in terms of speed and time. All from the view of the lab frame. Then you can solve for v.
Also, I have a rather old particle data book. It claims these ##\Omega^- ## live only ##8.22 \times 10^{-11}## seconds. For our convenience, it also mentions ##c\tau = 0.0246 ## m...
LOL... yeah, the OP contains a typo. :-p
Hah, yes! That would be a rather long time. Unfortunately it is too late to edit the original post.
Also, as Doc Al suggested, I need v to solve this problem. They give me the time and distance it travels in that time but not the velocity. I need to use time dilation to find the time in the rest (station?) frame and divide the distance by that time to find the velocity. I'm just getting mixed up on which t is which and how to solve for t overall.
The only time you are given is the proper time (in the muon's frame). What's the time in the lab frame? (Give an expression in terms of v, not a number.)
t=t0\sqrt{1-(\frac{v}{c})^2}, where t0 is given
Almost. Don't mix up t and t0. (Which must be larger?)
Moving clocks run slower so the time in the particle's proper frame will measure longer than the time in the 'station' frame. In that case t0 needs to be larger but you suggest t is given which flips my assumptions around. Is t0 not the time measured in the particle's proper frame?
Given your suggestion:
t0=\frac{t}{\sqrt{1-(\frac{v}{c})^2}}=\frac{t}{\sqrt{1-(\frac{x}{ct})^2}}
Should I be using t or t0 inside the square root?
Once I find t0 I can use that in my E calculation to find v?
Right.
No, just the opposite. The proper time is the shortest time. Every one else observes the particle's 'clock' to run slow. So everyone else measures a greater time.
Yes, t0 is the time measured in the particle's frame.
That's not my suggestion. That's just rewriting what you wrote before.
Inside the square root there should only be v, not time. You're going to solve for v.
t0 is given. Once you have the correct expression for t (lab frame time), you'll use it to express distance = speed*time as seen in the lab frame. The only unknown will be v, which you will solve for.
