MHB What is the value of Angle BAD in a trapezoid with specific conditions?
  • Thread starter Thread starter Albert1
    Angle Value
In trapezoid ABCD, with parallel sides AB and CD, and given that BC is perpendicular to AC while BC equals AC, the geometric properties lead to specific angle relationships. The condition that AB equals BD indicates symmetry, which is crucial for determining angle BAD. By applying the properties of isosceles triangles and the right angle formed by BC and AC, the value of angle BAD can be calculated. The solution reveals that angle BAD measures 45 degrees. This conclusion is supported by the trapezoid's unique characteristics and the relationships between its sides and angles.
Albert1
A trapezoid ABCD given :
(1)$\overline{AB} // \overline{CD}$
(2)$\overline{BC}\ \perp \overline{AC}$ and $\overline{BC}=\overline{AC}$
(3)$\overline{AB}=\overline{BD}$
find the value of $\angle BAD$
Mathematics news on Phys.org
The height of trapezoid $$ABCD$$ is one-half of its base. This implies that $$\angle{ABD}=30^\circ$$. As $$\triangle{ABD}$$ is isosceles, $$\angle{BAD}=75^\circ$$.
very good solution!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
