Find vectors making a certain angle with given vectors
  • Thread starter Thread starter LASmith
    Angle Vectors
10 replies · 6K views · last reply
LASmith
Find all unit vectors in R4 making an angle of [itex]\pi/3[/itex] with the three vectors
A=(1,1,-1,-1)
B=(1,-1,1,-1)
C=(1,-1,-1,1)
u.v=|u||v|cos[itex]\Theta[/itex]
using V=(w,x,y,z) as the vector we are trying to find, I solved the above equation for all three vectors A,B and C obtaining simultaneous equations to solve, however I obtained
x=y=z and w2-wx-x2=0
I am not sure how to solve this to find all unit vectors.
Also is there a method of doing this that I am unaware of?
How did you get w2-wx-x2=0? Did you use the fact that V is a unit vector?
I haven't yet considered the unit vector part, I was just going to divide the answer by the modulus.
I obtained this results as |u|cos[itex]\Theta[/itex] is 2*1/2=1 for all the vectors A,B&C therefore right hand side of the equation for all the vectors is |v|, so we get v.u=|v| and I took
|v| = [itex]\sqrt{}w<sup>2</sup>+x<sup>2</sup>+y<sup>2</sup>+z<sup>2</sup>[/itex]
I put C.u=B.u to obtain w-x-y+z=w-x+y-z which gave me that y=z
Then A.u=B.u to obtain w+x-y-z=w-x+y-z which gave me x=y
Then A.u=C.u to give w+x-y-z=w-x-y+z which gives x=z
so if you take x, y & z to all equal x (for example)
and use any of the equations we get w-x=[itex]\sqrt{}w<sup>2</sup>+3x<sup>2</sup>[/itex]
from this I got the w2-wx-x2=0
LASmith said:
and use any of the equations we get [itex]w-x = \sqrt{w^2+3x^2}[/itex].
from this I got the w2-wx-x2=0.
Recheck your algebra. The second equation doesn't follow from the first.
Also, if you use the fact that |V|=1, the first equation will give you w=1+x.
Okay, sorry I got the algebra wrong, I do not obtain w2-wx-x2=0 instead, I get w=-x. Which would be a solution, however, then fact vela pointed out w=1+x contradicts this, so what value am I supposed to use?
How'd you get w=-x? I got wx+x2=0. Try again!
Yes, I obtained this too, the you get x(w+x)=0
Therefore you get either x=0 or w+x=0 which leads to my answer w=-x
Heh. I didn't recognize the root. But there's no problem. You have two equations and two unknowns:
\begin{align*}
w+x & = 0 \\
w-x & = 1
\end{align*}
You can solve that.
Also, don't just ignore the x=0 solution as well.
vela said:
w+x & = 0 \\
w-x & = 1
\end{align*}
You can solve that.
therefore we get w=1/2 therefore x=-1/2 y=-1/2 and z=-1/2
Also using x=0 we get w=0, y=0 & z=0
so when it asks for all the unit vectors there must only be one, as the second one has a modulus of zero. So are they no more unit vectors apart from
(0.5,-0.5,-0.5,-0.5)?
You didn't handle the x=0 case correctly. In particular, it doesn't follow that w=0 from x=0.
Yes, I see it now, if x=0, then the |v|=1 still so we can use the equation w-x=1.
This implies that w=1, and as x=y=z=0
We get the second unit vector (1,0,0,0)
So there are two unit vectors for this answer. Thank you for all your help :)
