Finding a Basis for Perpendicular Vectors in R4
  • Thread starter Thread starter PenTrik
    Basis Subspace
To find a basis for the subspace of R4 that is perpendicular to the vectors (1,1,0,0) and (1,0,1,1), the dot product condition is applied, leading to two equations. The reduced row echelon form (RREF) of the system provides the equations x1 + x3 + x4 = 0 and x2 - x3 - x4 = 0. By expressing x1 and x2 in terms of free variables x3 and x4, the vectors <-1,1,1,0> and <-1,1,0,1> are derived. These vectors are confirmed to be perpendicular to the original vectors and linearly independent, thus forming a valid basis for the perpendicular subspace. The discussion concludes with the affirmation that these vectors indeed represent a basis.
PenTrik
Find a basis for each of these subspaces of R4
All vectors that are perpendicular to (1,1,0,0) and (1,0,1,1)
2. The attempt at a solution
I'm not sure how to approach this question. The only thing I can think of is that a vector that would be perpendicular to both would be where the dot product would equal zero aye?
So then that would give me
1x1 + 1x2 = 1x1 + 1x3 + 1x4 = 0.
So in which case, I'd do RREF
[[1,1,0,0]
[1,0,1,1]]
to
[[1,0,1,1]
[0,1,-1,-1]]
I get stuck here because I'm not sure how to solve for the basis at this point.
I'm also unsure if what I did for rref was correct because vectors are usually denoted by column spaces, rather than what row spaces such as what I have done.
That's the right start. But now you have to solve the linear equations. You've got 2 equations in 4 unknowns. You should be able to express the vector (a,b,c,d) in terms of two parameters by eliminating two unknowns. Can you do that?
I'm not sure if this is what I'm supposed to do but
Given that I have the RREF form, that gives me
x1 + x3 + x4 = 0
x2 - x3 - x4 = 0
Given that x1 and x2 are pivots, this gives me
x1 = -x3 - x4
x2 = x3 + x4
So, if I substitute x3 and x4 with a and b, this makes my basis the span of <-1,1,1,0> and <-1,1,0,1> ?
Well, both of those vectors are perpendicular to the given vectors. And they are linearly independent, so sure, they are a basis. The subspace they span is the perpendicular subspace, the span itself isn't a 'basis'. Those two vectors are a basis.
Ah, your help was much appreciated.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 58 ·
