Finding a constant of proportionality (Astro)
19 replies · 3K views
lquinnl
OK so I'm doing a past exam paper as some revision:
The central galaxy in the Perseus cluster has an X-ray spectrum in wavelength units
which is well described by the power law
[tex]F_\lambda \propto \lambda^{-2}[/tex] .
If the spectrum in frequency units is described by
[tex]F_v \propto v^\beta[/tex],
calculate [tex]\beta[/tex] .
Obviously we have [tex]v = \frac{c}{\lambda}[/tex]
so if [tex]v = \frac{c}{\lambda}[/tex]
then does that mean that [tex]\beta = -3[/tex]
I feel like I am really missing the point here. Any help would be greatly appreciated.
Thanks in advance!
How did you get -3?
Because lambda is to the power of -2 and lambda is related to frequency as v = c lambda^{-1} therefore adding an extra -1
does that make sense or is it total *@~% ?
I really cannot follow this logic. How does this "adding" come about?
Because
λ-1 λ-2 = λ-3
Am I on the right lines?
No, you are not. You really need to think how one could go from wavelength to frequency in a formula.
Looking at this again I am not convinced of my reasoning. I have this:
[tex]F_v \propto v^{-\beta}[/tex] .
[tex]F_v \propto v^{-\beta} \propto {\frac{c}{\lambda}}^{-\beta}[/tex] .
Any chance of a poke in the right direction, if you know?
You have a formula that contains [itex]\lambda^{-2}[/itex].
You need to express this formula via [itex]\nu[/itex]. How would you do it?
[tex]F_\lambda \propto \lambda^{-2} \propto (v^{-1})^{-2} \propto v^{-3}[/tex]
[tex]v \propto \lambda^{-1}[/tex]
[tex]F_v \propto v^{\beta} \propto \lambda^{-1} \propto (v^{-3})^{-1} \propto v^{-4}[/tex]
so [tex]\beta = 4[/tex]
P.s. Thanks for all this help.
lquinnl said:
[tex]F_\lambda \propto \lambda^{-2} \propto (v^{-1})^{-2}[/tex]
This part is correct.
But [itex](\nu^{-1})^{-2}[/itex] is NOT [itex]\nu^{-3}[/itex]. I note that you made a similar mistake in another derivation. What is the proper result of such an operation?
OF COURSE! I feel so stupid today, really need to wake up!
[tex](v^{-1})^{-2} = v^{2}[/tex]
so
[tex]F_v \propto v^{\beta} \propto \lambda^{-1} \propto (v^{2})^{-1} \propto v^{-2}[/tex]
and
[tex]\beta = 2[/tex]
Am I Right?
Or have I messed up still, regarding a sign?
This is correct. But what you do then puzzles me. You have just proved that since
[itex]\lambda^{-2} \propto \nu^{2}[/itex]
we have
[itex]F \propto \lambda^{-2} \propto \nu ^{2}[/itex]
What I'm saying is that
[tex]F_\lambda \propto \lambda^{-2} \propto v^{2}[/tex]
from [tex]v = \frac{c}{\lambda}[/tex] we have [tex]v \propto \lambda^{-1}[/tex]
so
[tex]F_v \propto \lambda^{-1}[/tex]
now i think maybe this should be how i follow:so
[tex]F_v \propto v^{\beta} \propto (\lambda^{-1})\propto(v^{2})^{-1}[/tex]
Again, you just got the expression in terms of [itex]v^{2}[/itex]. While you know it should be in terms of [itex]v^{\beta}[/itex]. What does this mean to you?
So if [tex]F_v \propto v^{\beta} \propto v^{-2}[/tex]
[tex]\beta = -2[/tex]
Why is this MINUS 2? Just two messages above it was PLUS 2.
I thought it should be minus 2 from this statement:
[tex]F_v \propto v^{\beta} \propto (\lambda^{-1})\propto(v^{2})^{-1}[/tex][/QUOTE]
I think you are very confused. Let me explain the whole thing to you.
When something (A) is proportional something else (B), then A = CB, where C does not contain B in any way.
In your case, you have F proportional to [itex]\lambda^{-2}[/itex], which means [itex]F = k\lambda^{-2}[/itex]
You are asked to find out to what degree of [itex]\nu[/itex] that is proportional. This is done by expressing [itex]\lambda[/itex] via [itex]\nu[/itex], which is [itex]\lambda = c\nu^{-1}[/itex], so you end up with [itex]F = k(c\nu^{-1})^{-2} = kc^{-2}\nu^{2}[/itex], which simply means that [itex]F \propto \nu^{2}[/itex] and [itex]\beta = 2[/itex].
THANK YOU VERY MUCH!
I feel like I have done an incredible job of over-complicating this problem!
I think I was getting confused by the fact we have F_v and F_lambda.
So it was just a case of expressing wavelength as frequency and amalgamating the powers.
Seems incredibly straightforward now!
Thanks again
