Finding a function given a limit and restriction
  • Thread starter Thread starter Mustard
    Function Limit
7 replies · 2K views
Mustard
Look at snippet
Look at snippet
Not sure how to go about this. Would relying on a hole or asymptote work?
Mustard said:
Homework Statement:: Look at snippet
Relevant Equations:: Look at snippet
yes, the function need not be continuous.
Hmmm... I was thinking of a function like f(x)= 4x-8/x-2 = 4(x-2)/x-2 = 4, that would make a hole at x=2.
But would also make f(2) = 4 ? Would it be safe to assume since there is a hole at (2,4) , it is undefined therefore f(2) does not equal 4 ?
The function has to be defined at x=2.
You can define it in a way everywhere except x=2, and define its value separately at x=2.
Do you mean like a piece wise function ?
You need more parentheses.
4x-8/x-2 means ##4x - \frac 8 x - 2##
and 4(x-2)/x-2 means ##\frac{4(x - 2)}x - 2##
When a numerator or denominator of a fraction contains multiple terms, you need parentheses around the whole numerator or denominator, like so.
f(x)= (4x-8)/(x-2) = 4(x-2)/(x-2)
Yes.
I suppose you can take any function, and define another function as that one multiplied it by (x - 2) and also divided by (x - 2) - I defer to the mathematicians as to whether that is formally a bona fide new function but even if it is it looks to me trivial and cheating.
The problem says that f(2) ≠ 4 but it doesn't say it has to be equal something or be defined. Probably you have studied before functions which at some point become equal to 0/0 but you were able to find their limit at that point? So you could adapt one of those, I guess that is what the question is expecting.
Two functions [itex]f : A \to B[/itex] and [itex]g: C \to D[/itex] are equal if and only if [itex]A = C[/itex] and [itex]B = D[/itex] and for every [itex]a \in A[/itex] we have [itex]f(a) = g(a)[/itex]. Thus [itex]f : \mathbb{R} \to \mathbb{R}[/itex] and [tex] g: \mathbb{R} \to \mathbb{R} : x \mapsto \begin{cases} \frac{(x-2)}{(x-2)}f(x) & x \neq 2 \\<br /> f(2) & x = 2 \end{cases}[/tex] are the same function, but if [itex]g(2)[/itex] is defined to be something other than [itex]f(2)[/itex] then they are not. However, [itex]g[/itex] is always equal to [tex] h: \mathbb{R} \to \mathbb{R} : x \mapsto \begin{cases} f(x) & x \neq 2 \\<br /> g(2) & x = 2 \end{cases}[/tex] which is easier to write and read.
I don't think it assists anyone to characterise an obvious or straightforward example which satisfies the conditions of the question as "trivial and cheating".
I would say that [itex]f(2) \neq 4[/itex] means that [itex]f(2)[/itex] is defined but is not 4. If a function for which [itex]f(2)[/itex] was not defined but [itex]\lim_{x \to 2} f(x) = 4[/itex] was wanted, then the question would have said exactly that; and [itex]f : \mathbb{R} \setminus \{2\} \to \mathbb{R} : x \mapsto 4[/itex] would work.
(It would be nice if the question had started "Find [itex]f : \mathbb{R} \to \mathbb{R}[/itex] such that ...")
