Finding a Left Inverse for a Cylinder: Proving Injectivity of a Parametrization
  • Thread starter Thread starter Z90E532
    Inverse
The discussion focuses on finding a left inverse for the parametrization function defined as ##f(x,y) = \left( \frac{x}{ \sqrt{x^2 + y^2}}, \frac{y}{ \sqrt{x^2 + y^2}}, \ln \left(x^2+y^2\right) \right)##, which maps from ##U \subset \mathbb{R}^2## to ##\mathbb{R}^3##. Participants clarify that the equation ##x^2 + y^2 = 1## represents a circle in ##\mathbb{R}^2## but a cylinder in ##\mathbb{R}^3##. The injectivity of the function can be established by analyzing the determinant of its Jacobian matrix, confirming that it is non-zero in the defined domain.
  • Understanding of parametrization in multivariable calculus
  • Knowledge of Jacobian matrices and their determinants
  • Familiarity with the concept of injective functions
  • Basic understanding of logarithmic functions and their properties
  • Study the properties of Jacobian matrices and how to compute them
  • Learn about the definitions and examples of injective functions
  • Explore the concept of left inverses in linear and nonlinear mappings
  • Investigate the geometric interpretation of parametrizations in higher dimensions
Students of multivariable calculus, mathematicians interested in parametrization and injectivity, and educators seeking to clarify concepts related to inverse functions and their applications in geometry.
Z90E532
Let ##S ## be a cylinder defined by ##x^2 + y^2 = 1##, and given a parametrization ##f(x,y) = \left( \frac{x}{ \sqrt{x^2 + y^2}}, \frac{y}{ \sqrt{x^2 + y^2} },\ln \left(x^2+y^2\right) \right)## , where ##f: U \subset \mathbb R^2 \rightarrow \mathbb R^3 ## and ## U = \mathbb R ^2 /{(0,0)}##
1. Find a left inverse of ##f##
2. Show that ##f## is injective.
I'm not even sure where to begin with this, My professor has done a very poor job of explaining how he wants us to go about these problems, and the book doesn't help much at all. The first thing that confuses me is that ##S## isn't a cylinder, it's a circle.
In class, we did inverses of simple functions which you could fairly easily solve, such as ##f(x,y) = (\sin xy, y)##, where we would just set it equal like this: ##y' = y## and ##\arcsin x' = xy##, then we would have ##f^{-1} (x',y') = (\frac{\arcsin (x'y')}{y'},y')##.
Also regarding the second question, I'm not aware of anyway to show that a function is injective unless its derivate is a square matrix, in which case you can take the determinant of the derivative and see where it's nonzero.
In R2, you are correct: the equation ##x^2 + y^2 = 1## represents a circle. In R3, though, the same equation represents a cylinder whose central axis lies along the z-axis. Your function f is a map from R2 to R3.
Also regarding the second question, I'm not aware of anyway to show that a function is injective unless its derivative is a square matrix, in which case you can take the determinant of the derivative and see where it's nonzero.
What's the definition of a left inverse that you are using?
  • · Replies 105 ·
12K
