Finding a vector from the curl of a vector
11 replies · 2K views
user1139
Consider the following
\begin{equation}
\nabla\phi=\nabla\times \vec{A}.
\end{equation}
Is it possible to find ##\vec{A}## from the above equation and if so, how does one go about doing so?
[Moderator's note: moved from a homework forum.]
\begin{equation}
\end{equation}
What do you get if you write this in components?
Working with Cartesian coordinates, I will be able to equate the respective components on the LHS and RHS. The problem comes when I want to find ##A_x##, ##A_y## and ##A_z## since the equations are now coupled.
Do you know how to solve it? I ran out of ideas.
You have ##c_1=z-y\, , \,c_2=x-z\, , \,c_3=y-x## which is ##\begin{bmatrix}
0&-1&1\\1&0&-1\\-1&1&0
\end{bmatrix}\cdot \begin{bmatrix}
x\\y\\z\end{bmatrix}=\begin{bmatrix}
c_1\\c_2\\c_3
\end{bmatrix}##
so invert the matrix and solve it. Of course you only get ##x\triangleq\dfrac{\partial A_1}{\partial x_1} ,\ldots##
The matrix is singular and hence, cannot be inverted.
\begin{equation}
\end{equation}
Let [itex]A = \nabla \times F + \nabla \psi[/itex]. Then [tex] \nabla \times A = \nabla(\nabla \cdot F) - \nabla^2F = \nabla \phi.[/tex] Adding a gradient to [itex]F[/itex] does not change its curl, which is all we care about, but does change its divergence, so we can assume [itex]\nabla \cdot F = 0[/itex]. That results in [itex]F[/itex] satisfying Poisson's equation [tex] \nabla^2 F = - \nabla \phi.[/tex] This is three decoupled equations in the cartesian components of [itex]F[/itex]. There is no way to determine [itex]\psi[/itex] since [itex]\nabla^2 \psi = \nabla \cdot A[/itex] is not specified.
There is an integral solution to ## \nabla \times A =\nabla \phi ##. It is basically a Biot-Savart integral type solution to ## \nabla \times B=\mu_o J ##, to solve for ##B ##. There is also the possibility of a homogeneous solution, (## \nabla \times A=0 ##), so that the solution for ## A ## is not unique by this method.
