Finding arbitrary rate of change.
The discussion revolves around calculating the rate of change of elevation for an object moving along a defined path on a hyperboloid surface. The elevation is given by the function Z = X^2 - 2Y^2, while the object's path is parametrized by X(t) and Y(t). Participants clarify that to find the rate of change of height with respect to time, one should differentiate the elevation function using the chain rule. The confusion about integration arises from the term "course," which refers to the path rather than suggesting a need for integration. Ultimately, the focus is on determining the height at time t and then calculating the derivative dz/dt.
NutriGrainKiller
The problem states that there is a glen described by the hyperboloid Z = X^2 - 2Y^2 and defined over [-2,1]x[0,2]. An object follows the course defined by X(t) = cos(t)cos(2t) and Y(t) = sin(t)cos(2t).
I have to compute the rate of change of the elevation of the object with respect to time at arbitrary time t.
I graphed the function and found the critical points, saddle points, local/absolute max/mins etc.., then i graphed the course parametrically and it resembled a four-leafed rose.
rate of change makes me think of taking the derivative, but course makes me think of integration. which direction should i take? vague replies only please (as always) :)
I assume that z is the elevation? The question is asking for a rate of change, so you want to differentiate (and my first sentence should be enough of a hint, if the assumption is correct). I am not sure why "course" made you think of integration :rolleyes:
The word course is referring to the parametrization of the curve
because course = path, thought of doing a double integral setting the limits to the position functions of x and y.
That doesn't help at all.
Here's what the problem actually is. You have a mountain, with the height at (x,y) defined in the problem. There is a trail, that a person is going up, defined by the parametrization. So you want to find the rate of change in the trail's height based on the parametrization variable, t. How do we start?
First question:
Can you find the height of the trail at time t?
Second question:
Can you find the rate of change of that height?
Find \frac{dz}{dt}. This is an exercise in using the chain rule.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
14K
11K
