Finding attenuation, phase constant, and velocity
4 replies · 7K views · last reply
DODGEVIPER13
Find the attenuation constant alpha, phase constant β, and phase velocity v if the conductivity of the material is σ=ωε the material parameters are μr=1, εr =2.5, and the wavelength in free space is λ naught = 30cm
So using some big hairy equations I found alpha to be equal to 9.53 nepers/m. The part I am having trouble with is the beta part? I start out using this equation β=sqrt((με/2)(1+sqrt(1+(σ/ωε)^2))). I have tried a ton of different ways to arrive at this equation β=(ω/c)(sqrt(εr))(sqrt((1+sqrt(2))/(2))) what do I do?
I can't reproduce your equations, sorry.
If we assume an E wave polarized in the y direction (propagation along x direction), the y component of E is
Ey = Emexp(jωt +/-Γx)
where Em = constant and
Γ is a (very!) complex number including ω, μ, ε, and σ. I leave it to you to obtain or derive this relationship. It will be in your textbook somewhere I'm sure.
Then, Γ = α + jβ so the answer to your problem is the imaginary part of Γ.
I went through it using the gamma equation I found in my book gamma= alpha+jbeta and then jomega(sqrt(mu(epsilon)))(1-j(sigma/((omega)(epsilon)))) once I had gamma I uses gamm=alpha+jbeta and found for beta using alpha I got 22.976
You have the right equation for Gamma.
You don't need alpha to get beta. Alpha is the real part of Gamma and beta is the imaginary part.
I did not check your numbers. What did you wind up with for alpha and beta in terms of omega, epsion, mu, sigma?
