Finding change in momentum in 2-dimensions.
To find the change in momentum of an object in two dimensions, calculate the initial momentum in both the x and y directions, then do the same for the final momentum. The change in momentum is determined by subtracting the initial momentum vector from the final momentum vector. This involves using vector subtraction in Cartesian coordinates. For magnitude, the formula is Δp = √((p1x - p2x)² + (p1y - p2y)²). Understanding these concepts is essential for analyzing momentum changes in two-dimensional motion.
Oxford365
To find the momentum change for an object in 2 dimensions do I find the initial momentum in both the x & y direction then apply the Pythagorean theorem, and then do the same for the final momentum and then find the difference between the two?
Momentum is a vector, so when you're looking for the change in momentum you're really looking for the difference between the initial an dthe final momentum vectors. Google for "vector subtraction Cartesian coordinates" and you'll find plenty of examples.
If you just want the magnitude,
##\Delta p = \sqrt{(p_{1x} - p_{2x})^2 + (p_{1y}-p_{2y})^2}##
  • · Replies 60 ·
  • · Replies 35 ·
  • · Replies 39 ·
