Finding determinant of Vandermonde matrix
  • Level: Undergrad
  • Thread starter Thread starter strugglinginmat
    Determinant Matrix
2 replies · 20K views · last reply
strugglinginmat
Can anyone help with finding the determinant of vandermonde matrix or the way in which I can start the problem. I did with 4X4 matrix but I would have to show that the generalisation that I get works for nXn matrix. Please anyone
It's a bit too messy to write down right now, but try to eliminate a row/column up to a single non-zero member and use Laplace expansion on that row/column and see where it gets you.
This Wikipedia article might help.
http://en.wikipedia.org/wiki/Vandermonde_matrix
The formula is given, but a proof is not given.
To prove the formula given in the article, replace the ith row by
1 x x^2 ... x^(n-1)
Then, take the determinant. The determinant is a function of x. Let's call it
V(x).
It is a polynomial in x of degree (n-1). Hence, it has (n-1) roots. Furthermore, V(a_i) is the value of the vandermonde determinant, and you know that letting x=a_j for any j between 1 and n(excluding i) makes the determinant 0. Hence, a_i is a root of the polynomial V(x). Thus, (a_i - a_j) is a factor in the expansion of V(a_i). Repeating this with each of the i rows tells us that that
det(V)= C product (a_j - a_i), where the product is taken over 1<=i<j<=n. C is a constant. The fact that C=1 follows from induction. To show that C=1, just consider the cofactor expansion along the last column and examine the coefficient of the highest power of a_n. This is again a vandermonde determinant. Hence, C is the same constant as the smaller Vandermonde determinant. Of course, you need to check that in the case n=2 that C=1.
Hope that was clear. I didn't write the solution super carefully, but the ideas are all there... Let me know if it made sense...
