Finding equation of both lines
  • Thread starter Thread starter Meeker
    Lines
To find the equations of the tangent lines to the graph of y=x^2 + 4 that pass through the point (1,-2), the derivative, which represents the slope of the tangent, is calculated as 2x. The slope of the line connecting a point on the curve (x, x^2 + 4) to (1, -2) should equal 2x. After determining the correct x-values, these points can be used to derive the equations of the tangent lines. The slope between the points is expressed as (x - 1) / (x^2 + 6). Ultimately, solving for x and substituting back will yield the desired tangent line equations.
Meeker
Determine the equation of both lines that are tangent to the graph of y=x^2 +4 and pass through the point (1,-2)
The derivative/slope of the tangent is 2x. But I'm not too sure what to do with this.
Ok so let (x,y) be a point on your curve. That makes it (x,x^2+4), right? Now find the slope of the line between that point and (1,-2). That slope should be your 2x, also right? Now solve for x.
Alright. Once I find x, what do I do with it?.
Btw, the slope for that line is (x-1)/(x^2+6) rite?
Slope is delta(y)/delta(x), isn't it? Once you find values for x, each one gives you a point on the curve that also goes through (1,-2). Use the points to find the line equations.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 26 ·
