Finding Force by using the coefficient of friction and mass
The problem involves a man pushing a 50 kg box up a 20-degree ramp at constant velocity, with a coefficient of friction of 0.4. The original poster attempts to determine the force exerted by the man while considering the effects of friction and the gravitational component acting down the ramp.
  • Participants discuss the forces acting on the box, including the gravitational force component along the ramp and the frictional force. There are inquiries about the original poster's attempts and the necessity of a free-body diagram to clarify the situation.
Some participants have provided guidance on the need for a detailed breakdown of the forces involved, emphasizing the equilibrium of forces acting on the box. There is recognition of the original poster's misunderstanding regarding the forces and a suggestion to clarify their calculations.
Participants note that the original poster has sought help from a teacher and has indicated a misunderstanding related to the use of trigonometric relationships in their calculations.
Alejandro Nava
A man pushes a 50 kg box up a 20-degree ramp at constant velocity. If the pushing force is parallel to the ramp, and the coefficient of friction is 0.4, how much force is he pushing with?
u=Fs, max/Fn Not sure if this equation is needed.
I tried to solve the problem but I ended up getting the frictional force instead of the force he is pushing with.
Show us the details of what what you've tried so far.
Make a free body diagram.
Forces parallel to ramp mgsin(θ) and μFn. The man is pushing against weight component down the slope and friction.
Is that all?
What you wrote here does not qualify as "attempt at a solution". You told us you couldn't do it (which is automatic when someone posts something in this subforum), but without seeing what you actually did, there is no way anyone can diagnose what you did wrong.
We are not allowed to give you outright solutions. We are, however, allowed to help you find the solution. And to do that, we need to know what you actually did. So show your work, especially your free-body diagram, as has been suggested.
Zz.
kuruman said:
Is that all?
Yes.
neilparker62 said:
Yes.
What about the man pushing?
As mentioned in my post, the man is pushing against the above-mentioned forces and there will be zero resultant force since the block does not accelerate.
I agree that the resultant force is zero. I disagree about the number of forces acting on the block. I can count 3 in the direction parallel to the incline that should add to zero: pushing force by man, friction by incline, component of gravity. How many are there according to your count?
Quite right - there are 3 forces in equilibrium so the OP will need to add two of them to obtain the third. Or alternatively add all 3 and set equal to zero with the pushing force being the unknown.
You got it! :smile:
kuruman said:
You got it! :smile:
More importantly I hope the OP did too!
Thank you all for trying but I ended up going to the teacher to ask how to do the problem and I understand how to do the question. What I did wrong was that when I was trying to find the force, I used COH instead of TOA. Sorry for the inconvenience.
Perhaps this was the correct response to the OP's query! I'm not sure what either COH nor TOA mean.
  • · Replies 16 ·
9K
