Finding golf balls in the rough (ultrasonic idea)
  • Thread starter Thread starter MIMSAR
    Balls Golf Idea
A solution is being designed to locate golf balls in the rough, focusing primarily on an ultrasonic system to detect solid objects in grass. The idea is to create a portable device that golfers can use while walking, providing feedback when a ball is detected. The discussion explores whether a solid golf ball would reflect ultrasound waves more effectively than grass. Additionally, there are considerations regarding the use of UV light to detect the ball's fluorescent coating, although sunlight interference may pose challenges. The feasibility of these methods is still under investigation, particularly the effectiveness of ultrasound in differentiating between a ball and other solid objects.
MIMSAR
Hi,
I'm trying to design a solution to the problem of finding golf balls in the rough. I've had a few thoughts so far:
- Image processing to detect white objects in a predominantly green environment
- UV light emitter and detector to take advantage of fluoresence of the whitening coating of the ball
- Ultrasonic system to detect solid objects in grass, followed by profiling to determine shape
I expect the system should be portable so golfers can scan the grass as they walk and receive some feedback when a ball is found.
My main focus is on the latter idea and I was wondering if anyone with any experience of ultrasound knew if this was possible. Would, perhaps, the solid ball reflect ultrasound waves more strongly than a clump of grass? Once I've established if this works I can (attempt to) devise a system to ID a ball from any other solid object.
Thanks.
I believe ultrasound requires a certain density medium to effectively travel through and get a response. Although the transmitter/emitter is probably adjustable...
This is just an assumption based on the ultrasound probes used to check out fetus's (feti?) shape and size during pregnancy.
I also like the idea of the UV light emitter, but I have a feeling the sunlight could pose a problem when trying to detect reflected UV light, maybe not once again, I'm no expert but I hope it helps.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
