Finding Maximum Altitude of a Rocket
41 replies · 7K views · last reply
stupif
1. a rocket is launched from rest and moves in a straight line at 70degree above the horizontal with an acceleration of 46ms^(-2) . After 30seconds of powered flight , the engines shut off and the rocket follows a parabolic path back to earth. find
1)the maximun altitude reached
2. i use this formula, s= ut +1/2at^2
s=? , u=0, t= 30, a= (46-9.81 )
the correct answer is 105.16km, i didt get the answer~
3. why can't get the answer and how should i do to get correct answer?
   help me...thank you
During the powered portion of the flight you are given the rocket's angle and acceleration, and told that the trajectory is a straight line. So at the end of the powered portion (20 seconds duration) what is the speed of the rocket and its height? How about the vertical component of its speed?
stupif said:
use which one formula?
For speed, use a formula that includes acceleration and time and gives velocity.
For distance, use a formula that includes acceleration and time and gives distance :smile:
What formulas do you know?
i know this formula, v= u + at
s= ut +1/2at^2, correct?
Yes, fine. Which one will give you the speed of the rocket, traveling in a straight line with acceleration a=46ms-2 for 30 seconds?
1380m/s??
after that?
i use this formula s=ut+1/2 at^2 to find distance
u= 0, t=30 a=46, correct?
stupif said:
1380m/s??
after that?
Yes, fine so far. Determine the height of the rocket at burnout from its distance traveled (it's been traveling at a 70° angle, remember). From the speed and angle, determine the vertical component of the velocity. Then treat these circumstances as a new projectile problem for the unpowered portion of the flight.
s=ut +1/2 at^2
s= 1380sin 70(30)+ 1/2 (46)(30)^2
my answer is 59.603km
but answer is 105.16km
stupif said:
s=ut +1/2 at^2
Your speed, 1380m/s is at the *end* of the 30 second burn. It is not the initial velocity of the rocket (that's zero).
You are currently looking for the height of the rocket when its fuel runs out (after 30 seconds). What is that height?
Using the formula that gives you distance when you know the acceleration and time.
Nope. Use s = (1/2)at2
You can either calculate the distance along the straight trajectory and then find the vertical height at the end using the trajectory's angle with the horizontal, or you can calculate the height directly by using in the formula only the vertical component of the acceleration.
stupif said:
sorry...you are confusing me...
Let's see if we can fix that :smile:
Attached is a diagram of the rocket trajectory. It's a straight line until the fuel runs out after 30 seconds, at which point it will have traveled some distance s along the trajectory and reached height h1 with some speed v. This speed will be directed along the trajectory (angle 70° to the horizontal).
After burnout the rocket is just a projectile with a ballistic (unpowered) trajectory. It's a parabolic trajectory.
So there are two sections of the trajectory to worry about. First the powered section, which you are told is a straight line with a given acceleration, and the second is a simple projectile motion with an initial velocity and height and launch angle (70°).
The first order of business is to find out where the rocket is at the end of the powered section, and how fast it is traveling. Those will in fact be the initial conditions for the second section of the trajectory. The distance it travels in that first section is designated s in the figure. The height it achieves is h1.
Now, to find the height of the rocket you can either find s using the given acceleration along the straight line for the specified time (30 seconds) and then use trig to find the vertical distance from that, or you can realize that the acceleration has both vertical and horizontal components and use the vertical component of acceleration to find that height. In either case the formula to use is (1/2)at2. In the first case the acceleration is a=46m/s2, directed along the trajectory. In the second case it's the vertical component of a (use the angle and trig to break the 46m/s2 into its vertical and horizontal components).
Does that help?
now, i really understand the question, you are too great.
thank you.
but how to find h2,
i use this formula, v=u +2as
u=1380m/s, a=9.8, v=0
now, i really understand. you are too great. thank you very much
but now h2 how to find?
i use this equation v= u +2as
v= 0, u= 1380 a=9.8
v= 0, u= 1380 a=9.8
First, let's make sure that you've got the first height. What did you get for h1?
when I was learning this stuff, you just got to grasp your head around the x speed always staying constant with only the y speed changing.
stupif said:
my h1 is 20700m
That seems just a bit too big. It looks like it might be the distance s, measured along the straight line trajectory, rather than the height h1, which is the vertical component. Can you show your calculation?
stupif said:
s= ut + 1/2 at^2
= 0(30) +1/2 (46)(30)^2
As I surmised, that calculation gives you the length of the straight line trajectory, s in the diagram that I made, rather than the height. This distance forms the hypotenuse of a triangle which has the height h1 as one side and the horizontal distance traveled as the other. You should be able to calculate h1 using s and the angle that s makes with the horizontal.
stupif said:
20700 sin 70??
Yes. That will be the height h1 where the powered part of the trajectory ends (at t = 30 seconds) and the free-fall part of the trajectory begins. Make a note of that value.
Now let's turn to the second portion of the trajectory. The rocket, with its fuel gone, is now a simple projectile. It has an initial speed, height, and launch angle, and you want to find the highest elevation achieved. What approach will you take? (Do you know of more than one?)
(Remember that the rocket's velocity will have both vertical and horizontal components, and that the speed you calculated previously is the speed in the direction of the straight-line portion of the trajectory -- it's the magnitude of the velocity vector).
speed is 1380sin70 + 1380cos70 =1768.76m/s
then i v^2 = u^2 +2 as, 0=1768.76^2 +2(9.8)s
s= 159617.96m.
correct?
s= 159617.96m.
correct?
Well... You want to use just the vertical component of the velocity, 1380sin70. That's the only part of the velocity vector that's acting to change the height of the rocket.
Also, linearly adding the magnitudes of the vertical and horizontal components of a vector together doesn't yield a meaningful quantity. Vector components "add in quadrature", which, translated into plainer terms means that they add like the sides of a right angle triangle "add" to yield the hypotenuse: [itex]v = \sqrt{v_y^2 + v_x^2}[/itex]. Here v is your speed, 1380 m/s, and vy and vx are the vertical and horizontal components of that speed.
