Finding maximum distance of a lit power source
02drai
The minimum energy of the visible lights of wavelength 500to 600 nm that can just be detected by the eye is 10e-17Watts. Only 1% of power input to a 60W light bulb is emitted between these wavelengths. Estimate the maximum distance that it might be possible to see the lit bulb. The pupil of the eye will be at its maximum diameter say 8mm. At its maximum sensitivity the eye only detect 8% of the light incident on it.
My answer
Minimum power the eye can detect= 10e-17w
1% of 60w=0.6w
Therefore, the maximum distance to see the lit bulb,
Power output ÷ surface area of a sphere = power per meter square
0.6÷(4πr^2)=10e-17
0.6÷10e-17=(4πr^2)
(6X10^16)/4π=r^2
so r=sqrt(6X10^16)/4π)
r= 217080km however in answer is 140km.
Please help me with this. Thanks.
You're problem is units! There's a reason that you've been given more information that you're actually using. On the left you have power per square meter. But the piece of information you used on the right has units of power.
Break the problem into a couple different stages: figure out how much of the pupil area, which I think should be safe to assume as a circle, relates to that minimum power, and then figure out how much of that quantity relates to the power radiated/m^2.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
