Finding minimum value of force P given static friction
The discussion focuses on determining the minimum force P required to move a crate on a horizontal surface, given the coefficient of static friction us and an angle theta. The formula for P is derived as P = (us*Fg*sec(theta)) / (1 - us*tan(theta)). While the initial part of the problem was solved, the user struggled with finding the minimum value of P when us is 0.400. A suggested approach involves differentiating the expression for P with respect to theta and setting it to zero to find the minimum. The conversation emphasizes simplifying the resulting equation to facilitate solving for the angle that minimizes P.
Zipzap
A crate of weight Fg is pushed by a force P on a horizontal
floor. (a) If the coefficient of static friction is us and P
is directed at angle theta below the horizontal, show that the
minimum value of P that will move the crate is given by
P = ( us*Fg*sec(theta)) / (1 - us*tan(theta))
(b) Find the minimum value of P that can produce motion
when us " 0.400
All right, I managed to do (a) on my own, but I'm dead stuck on (b). I've only gotten as far as inputting us = 0.400 in, and all I know is that I need to find an angle such that I get a minimum for P. I'm unsure as to how to solve this problem without inputting a bunch of angles and using trial-and-error to get my answer. Can anyone help me?
Differentiate your expression for P with respect to Theta and set it to 0, find the minimum in the usual way. I think that will work.
You will need to solve that equation. It's not as bad as it looks. Straight away you can simplify it by multiplying top and bottom of the second fraction by 1-0.4tan(x), then the denominators for both are the same, so you can throw them away and you have:
\frac{0.16}{cos^{3}(x)}+\frac{0.4sin(x)}{cos^{2}(x)}-\frac{0.16sin^{2}(x)}{cos^{3}(x)}=0
You can solve this to get the root you want in a simpler form than it is given on the WolframAlpha page.
Keep in mind that 1-sin^2(x)=cos^2(x), this property is useful in the process of solving the equation.
10K
  • · Replies 42 ·
9K
