Finding P(X1<X2<X3) and P(X1=X2<X3)
  • Thread starter Thread starter cookiesyum
12 replies · 17K views
cookiesyum
Let f(x1, x2, x3) = e-(x1+x2+x3), 0<x1,2,3<infinity, zero elsewhere be a joint pdf of X1, X2, X3.
Compute P(X1< X2< X3) and P(X1= X2< X3)
Determine the joint mgf.
P(X1< X2< X3) = triple integral of e-(x1+x2+x3) dx2dx1dx3 as x2 goes from x1 to x3, x1 goes from 0 to x2 and x3 goes from x2 to infinity.
When I solve this integral I get 0 for an answer. The back of the book suggests the answer is 1/6. Clearly, I am setting up the problem wrong, but I don't know where my mistake is. Similarly, I'm having trouble setting up the second part of the question as well.
Joint mgf = E(et1x1+t2x2+t3x3) but this integral is not easy by hand. Is there another way to do it?
on Phys.org
Yeah, your integration limits are incorrect. For P(x_1<x_2<x_3), start from x_1. Say it goes from zero to infinity. Then x_2 has to go from x_1 to infinity, and likewise x_3 goes from x_2 to infinity.
What's hard about solving the MGF?
[tex]E(e^{t(x_1+x_2+x_3)}) = \int dx_1 dx_2 dx_3 f(x_1,x_2,x_3) e^{t(x_1+x_2+x_3)} = \int dx_1 dx_2 dx_3 \exp [(t-1)(x_1+x_2+x_3)][/tex]
I'm sure you know how to integrate an exponential function.
Oh! I was doing it with three different t's ... t1 t2 and t3 which made it a million times harder. That makes sense. Thanks so much!
I guess you do need multiple t's. It doesn't make it any harder though.
No, you don't need multiple ts.
[tex] \phi(t)_{X_1+X_2+X_3} = \idotsint e^{t(x_1+x_2+x_3)} f(x_1,x_2,x_3)\,dx_1dx_2dx_3[/tex]
Aren't your variables independent exponentials?
Yep, finally got the answer. Thank you everybody for your help!
What about P(X1=X2<X3)?
The random variables are drawn from a continuous distribution, and are independent. Do you know what the probability is that a continuous random variable will be exactly some specified number?
zero, it must be an interval... So then would it be P(X1=X2<X3) = P(X1<X3)*P(X2<X3) or even P(0<X3)?
You are correct that this is the joint mgf (with three different t's). If you had t1 = t2 = t3 = t, as some others have suggested, you would be finding the mgf of the single random variable X = X1 + X2 + X3. Anyway, the integral is *very easy* by hand.
RGV
RGV
I have a question about the mgf...
So this is the integral that we need to integrate, right?
[itex]\int_0^{\infty} \int_0^{\infty} \int_0^{\infty} e^{x_1(t_1-1)} e^{x_2(t_2-1)} e^{x_3(t_3-1)} dx_1 dx_2 dx_3[/itex]
But I'm having some trouble with this, because this is what I get after integrating...
[itex]\frac{1}{t_1-1}e^{x_1(t_1-1)} |_0^{\infty} \frac{1}{t_2-1}e^{x_2(t_2-1)} |_0^{\infty} \frac{1}{t_3-1}e^{x_3(t_3-1)} |_0^{\infty}[/itex]...but if we plug in infinity to [itex]\frac{1}{t_1-1}e^{\infty(t_1-1)}[/itex]...don't we get infinity, since e increases forever?
That depends on whether t-1 is positive or negative.
Thanks a lot...
