Finding <φₙ|x|φₘ> for harmonic oscillator without integration
17 replies · 7K views
natugnaro
Is there any way to find [tex]<\varphi_{n}(x)|x|\varphi_{m}(x)|>[/tex] (where phi_n(x) , phi_m(x) are eigenfunction of harmonic oscillator) without doing integral ?
perhaps orthonormality of hermite polynomials ?
[tex]\int^{+\infty}_{-\infty}H_{n}(x)H_{m}(x)e^{-x^{2}}dx=\delta_{nm}(Pi)^{1/2}2^{n}n![/tex]
Actually i need to find <x> from known [tex]\psi(x,t)[/tex].
[tex]<x>=<\psi(x,t)|x|\psi(x,t)|>[/tex]
This gives me a lot of [tex]<\varphi_{n}(x)|x|\varphi_{m}(x)|>[/tex] terms, some of them cancel out (for m=n) ,
but at the end I'm left with three terms thath I have to calculate ([tex]<\varphi_{1}(x)|x|\varphi_{2}(x)>,<\varphi_{2}(x)|x|\varphi_{3}(x)>, <\varphi_{3}(x)|x|\varphi_{1}(x)>[/tex]
and that also looks like a lot of work.
final result is <x>=0
(This is problem from Schaums QM (supplementary prob.))
There is a recurrence relation, which is satisfied by the Hermite polynomials
[tex]H_{n+1}(x)=2\,x\,H_{n}(x)-2\,n\,H_{n-1}(x)\Rightarrow x\,H_n=\frac{1}{2}\left(H_{n+1}(x)+2\,n\,H_{n-1}(x)\right)[/tex]
Thus you do not have to do the integrals, i.e.
[tex]\int^{+\infty}_{-\infty}H_{1}(x)\,x\,H_{2}(x)e^{-x^{2}}dx=\int^{+\infty}_{-\infty}H_{1}(x)\left(\frac{H_{3}(x)+4\,H_{1}(x)}{2}\right)e^{-x^{2}}dx=2\,\int^{+\infty}_{-\infty}H_{1}(x)\,H_{1}(x)e^{-x^{2}}dx=4\,\sqrt{\pi}[/tex]
Similar expressions hold for the other integrals.
natugnaro said:
No, I'm not familiar with Ladder operator method.
ok, it is very powerful and it is used very often in QM (more than just about harm osc). Send me a private message and I'll teach you if you want ;)
Thank's Rainbow Child, that is really useful.
Using this recurrence relation for hermite polynomials and [tex]<\varphi_{n}(x)|x|\varphi_{m}(x)>=<\varphi_{m}(x)|x|\varphi_{n}(x)>*[/tex]
I was able to reduce <x> to the form:
[tex]\frac{2}{7}(4\sqrt{\pi}A_{1}A_{2}e^{i\omega t}+4\sqrt{\pi}A_{1}A_{2}e^{-i\omega t}+24\sqrt{\pi}A_{2}A_{3}e^{-i\omega t}+24\sqrt{\pi}A_{2}A_{3}e^{i\omega t})[/tex]
Where An's are normalization constants, but I don't see how this leads to <x>=0 ?
Even if I expand, just Sin(wt) terms will cancel out, but not Cos(wt).
(It is problem 5.15 from Schaum's QM)
\pi and \cdot
if you want to learn real QM, try ladder operators (A)
malawi_glenn said:
\pi and \cdot
I'll keep that in mind.
If I don't solve the problem this way, I'll send you a message again.
Your answer is correct (up to constants, I didn't carried out the whole calculations). The only case where [itex]<x>=0[/itex] would be if we had eigenfunctions of harmonic oscillator of the form
[tex]\varphi_{n}(x),\varphi_{m}(x)[/tex]
with [tex]n\neq m\pm 1[/tex]
Only in this case the integrals
[tex]\int_{-\infy}^{+\infty}H_n(x)\,x\,H_m(x)\,e^{-x^2}\,d\,x=\int_{-\infty}^{+\infty}H_n(x)\frac{1}{2}\left(H_{m+1}(x)+2\,m\,H_{m-1}(x)\right)\,d\,x=\frac{1}{2}\int_{-\infty}^{+\infty}H_n(x)H_{m+1}(x)\,d\,x+m\,\int_{-\infty}^{+\infty}H_n(x)\,H_{m-1}(x)\,d\,x[/tex]
would vanish. Thus there must be a typo error in the book! :smile:
I didn't get the constants right up there.
I did the thing again and find
[tex]<x>=\frac{2(2+\sqrt{3})}{7}Cos(\omega t)\sqrt{\frac{\hbar}{m\omega}}[/tex]
At last I've tried also ladder operators (thanks malawi_glenn).
[tex]x=\sqrt{\frac{\hbar}{2m\omega}}(a+a^{+})[/tex]
then using
[tex]a|k>=\sqrt{k}|k-1>[/tex]
[tex]a^{+}|k>=\sqrt{k+1}|k+1>[/tex]
arrive at
[tex]<n|x|k>=\sqrt{\frac{\hbar}{2m\omega}}(\sqrt{k}<n|k-1>+\sqrt{k+1}<n|k+1>)[/tex]
where n and k are eigenfunctions of H.O.
From here it's easy, I just use the dot product.
There is a solved problem in Schaums QM for this.
I got the same result for <x> using ladder op. ,that's nice :smile:.
Ok, I'm going to mark this thread as solved even though the solution in the book is <x>=0.
how about this: ?
[tex]a|n>=\sqrt{n}|n-1>[/tex]
[tex]a^{\agger}|n>=\sqrt{n+1}|n+1>[/tex]
[tex]<n|x|n> =\sqrt{\frac{\hbar}{2m\omega}}(\sqrt{n}<n|n-1>+\sqrt{n+1}<n|n+1>) = 0[/tex]
malawi_glenn said:
how about this: ?
Ok, but I have <1|x|2> and <2|x|3>, so I can't have zero, right ?
no of course not, but the case <n|x|n> = <x> = 0, I thought you said that you did not understand why you did not get it.
The thing you have: <n|x|k> is correct, just plug in your values for n and k and you will get the correct answer.
Ok, no problem .
As Rainbow Child said "Thus there must be a typo error in the book!" :smile:
natugnaro said:
Ok, no problem .
ok, but <x> always refer to be taken between same two states.
So your tasks was to calculate:
<x> and <1|x|2> and <2|x|3> ?
What does your book give for answers?
Here is the text from the book:
The wave function of a harmonic oscillator at time t=0 is
[tex]\psi(x,0)=\sqrt{2}A\phi_{1}+\frac{1}{\sqrt{2}}A\phi_{2}+A\phi_{3}[/tex]
Where phi_n is stationary eigenfunction of the harmonic oscillator for the nth state,
and A is normalization constant.
a) compute A.
b) find psi(x,t) for all values of t.
c) calculate the average values of <E> at times t=0, t=Pi/w, t=2Pi/w.
d) find expectation values <x> and <p> for t>=0.
a) done that , got result as in the book
b) done that, got result as in the book
c) skipped that
d) calculated just <x>, <x>=2(2+sqrt(3))/7 * sqrt(h/(2Pi*mw))*Cos(wt)
Solutions from the book:
a) [tex]A=\sqrt{2/7}[/tex]
b) [tex]\psi(x,t)=\sqrt{2/7}(\sqrt{2}\phi_{1}e^{\frac{-3i \omega t}{2}}+\frac{1}{\sqrt{2}}\phi_{2}e^{\frac{-5i \omega t}{2}}+\phi_{3}e^{\frac{-7i \omega t}{2}})[/tex]
d) <x>=0 , <p>=0
Great, always post the original question in the first post so no confusion aries :)
You now also know how to write p as a combination of a and a(dagger).
shall see if can get the right values for <x>
Yes, I should have done that :redface:
