Finding Radius & Interval of Convergence
11 replies · 2K views
Jbreezy
Find the radius of convergence and the interval of convergence
A_n = Ʃ sum n =1 to infinity [((-1)^n) x^(2n+1)]/(2n+1)!
All I thought was to use the ratio test so I did A_(n+1) /A_n
= ((x^(2n+1))/(2n+1)!) ( (2n+1)!)/ [x^(2n+1)]
I got |x^2| limit n ---> |x^2 / 4n^2 +10n +6 | when I simplified and such. So the limit is equal to 0 so my interval of convergence is 0 ? and R = 0?
If the limit of A_(n+1)/A_n is zero, the radius of convergence is not 0. Check how the ratio test works.
It is true that the limit is 0. However, this does not mean that the radius of convergence is 0. You did the more difficult part correctly, take a other look at the definition of ratio test and how to find radius of convergence from that.
Less then one. Converges right? Radius of convergence umm |x^2| < 1 so x < +-1?
No?
Not quite. Are you familiar with a simple equation relating limit and radius of convergence?
No. It converges for all values of x so radius of convergence is infinity for all x? What is the equation?
That's correct. It does indeed converge for all values of x. And the small equation I was referring to is R (radius of convergence) = 1/L (the limit). You assume that 1/infinity = 0 and 1/0 = infinity. So in this case, your answer for the limit is 0, so 1/0 = Infinity which implies an infinite radius of convergence.
Question when using the ratio test for power series and your limit is equal to 1 then you just...like this
|x| limit n --> (n^2 +1)/(n^2 +2) = |x| (1) then you say
You need |x| <1 and go from there? Even though your limit is one you can still use it although with the ratio test if you get a limit of 1 it is inclusive?
Yes. What you can say is if the limit is 1, the radius is also one, so you can find the interval by adding and subtracting 1 from the center, even though the ratio test for convergence is I conclusive. That is because in this case, you aren't looking for the limit (which would be an inconclusive convergence test). Rather, you want 1/L, so it doesn't matter in this case that the ratio test for convergence is inconclusive.
Where did you get your 1/L radius of convergence eq. ? I want to read this
I am currently in the same class (i assume integral calculus) and that is what we were taught.
It is true, and you can prove it. For a series around the origin (everything else is just more to type, it does not change anything):
Assume the ratio of ##\displaystyle \frac{|A_{n+1}|}{|A_n|}## approaches a limit of L.
Consider an arbitrary value of x with |x|<1/L.
Then the ratio ##\displaystyle \frac{|x^{n+1}A_{n+1}|}{|x^n A_n|} = |x| \frac{|A_{n+1}|}{|A_n|}## approaches |x|*L < 1. Therefore, the series converges at that point via the regular ratio tests for series.Consider an arbitrary value of x with |x|>1/L.
Then the ratio ##\displaystyle \frac{|x^{n+1}A_{n+1}|}{|x^n A_n|} = |x| \frac{|A_{n+1}|}{|A_n|}## approaches |x|*L > 1. Therefore, the series does not converge at that point via the regular ratio tests for series.Therefore, the radius of convergence is R=1/L.
With the definitions 1/0=infinity, 1/infinity=0 this proof works for the two special cases as well.
