Finding Static Equilibrium: Solving for Unknown Angles
To solve for unknown angles in static equilibrium problems, it is essential to set the sum of forces (ΣF) and the sum of moments (ΣM) equal to zero. A clear problem statement and a free body diagram can help identify knowns and unknowns. It is important to convert mass from grams to kilograms to express forces in Newtons correctly. The inclusion of angles in problems may sometimes serve to complicate the solution process. Understanding these elements is crucial for successfully solving the problem.
Ping427
Can anyone help me with this question! I know to solve this problem, you have to set ΣF and ΣM =0, but what do you do with angle? (It's P.31 in the bottom)
Hi Ping, welcome to PF :smile: !
Sure! To get started, extract a complete and concise problem statement from this moving stoy. That helps you sort out what's known/unknown and what's relevant/irrelevant. Then help us help you at the appropriate level by typing some equations relating the variables that occur.
What also heklps is a free body diagram showing the forces that act.
Then try to solve and type what you do. At the point where you get stuck we'll gladly help you further. Also see the guidelines.
PS my neck hurts from trying to read from bottom to top.
This is what I did, but it looks wrong to me
Why do you think you need to do anything with the angle? The location of the center of gravity for the music player is shown on the figure. :wink:
If you want to express the reactions Ay and By in correct SI force units of Newtons, you should change the masses of the music player and the docking station from grams to kg at the beginning.
So they just place a angle there to trick me?
Sadly, yes.
SteamKing said:
Sadly, yes.
Thank you for telling me!:smile:
