Finding Tension in a String Holding a Meter Stick Against a Wall
  • Thread starter Thread starter proace360
    Wall
5 replies · 5K views
proace360
A 0.13 kg meter stick is held perpendicular to a wall by a 2.7 m string going from the wall to the far end of the stick.
(a) Find the tension in the string.
(b) If a shorter string is used, will its tension be greater than, less than, or the same as that found in part (a)?
(c) Find the tension in a 2.0 m string.
Torque=Nr?
I discovered the angle to be 68.38 degrees, and I thought that, since the y-component of the force cancels out mg, T=mg/sin(theta). Why is it wrong?
on Phys.org
The string tension is not the only force (besides the weight) acting on the stick.
I know that the wall exerts a horizontal force, but that doesn't matter in the Fy equation.
wait... how does it exert a vertical force? Is there a friction force?
There better be. But you need not worry about the wall force to solve this problem.
