Finding the angle of an electron striking a plate
3 replies · 2K views
chef99
An electron is fired at 4.0 x 106 m/s horizontally between the parallel plates, as shown, starting at the negative plate. The electron deflects downwards and strikes the bottom plate. The magnitude of the electric field between the plates is 4.0 x 102 N/C. The separation of the plates is 2.0 cm.
a) Find the acceleration of the electron between the platesa) Find the horizontal distance traveled by the electron when it hits the plate
Fnet y = FE - Fg
ΔDy =v1y Δt + 1/2 a Δt2
ΔDx = v1x Δt
vf = vi + (a)(t)
a)
Let right and down be positive.
Fnet y = FE - Fgma = qε - 0a = qε / ma =https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image002.png (1.6 x10-19C)(4.0 x102N/C) / (9.11 x10-31kg)a = 7.03 x1013m/s2 [down]The acceleration of the electron is 7.0 x1013m/s2 [down].
b)
In order to calculate the distance traveled, the value of time (https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image001.pngt) must be determined.https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image002.pngΔDy =v1y Δt + 1/2 a Δt20.02m = 0 Δt +https://www.physicsforums.com/file://localhost/Users/jefferyhewitt/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image007.png1/2 (7.03 x1012) ΔtΔt = √(0.02m)(2) / (7.03 x 1013)Δt = 2.38 x10-8 sNow the value of time can be used to determine the horizontal distance traveled by the electron:
ΔDx = v1x Δt
ΔDx = (4.0 x106m/s)(2.38 x10-8s)
ΔDx = 9.5m
The horizontal distance traveled by the electron is 9.5m.c)
vf = vi + (a) (t)vf = (4.0 x106m/s)(7.03 x1013m/s)(2.38 x10-8s)vf = 6.69 x1012 m/sThe velocity of the electron as it strikes the plate is 6.7 x1012 m/s [ ].I think this is all right but, the one thing I don't know how to do but I think I have to determine the angle at which the electron strikes the plate. If anyone has suggestions I would greatly appreciate it.
on Phys.org
haruspex said:
Check those two steps.
Thanks for pointing that out.
So
ΔDx = 0.0952
ΔDx = 9.5 x10-2m
and
vf = vi + (a) (t)
vf = 5673140
vf = 5.7 x106m/s
Also for c) do I have to determine the angle the electron strikes that plate or not?
chef99 said:
vf = vi + (a) (t)
this is still not right. You need to distinguish between directions. The initial velocity is at right angles to the acceleration.
Also, you did not post the question for part c. If it asks for a velocity then the answer should consist of a speed and a direction.
