Finding the angular velocity and rotational kinetic energy
18 replies · 4K views
PhyIsOhSoHard
A solid cylinder is rolling along a horizontal plane and is friction less around its symmetric axis. The cylinder is pulled by a constant force, F and travels the distance, d. The cylinder does not glide and has a friction force, f on the ground.
Known values:
Mass: M
Radius: R
Moment of inertia: ##I=\frac{1}{2}MR^2##
Force: F
Angle of the force: θ
Friction force: f
Distance traveled: d
Angular acceleration: α
Find the angular velocity and rotational kinetic energy for the cylinder when it starts at rest and travels the distance d.
[itex]\frac{d\omega}{dt}=\alpha[/itex]
[itex]K=\frac{1}{2}I\omega^2[/itex]
From a previous question, I found the angular acceleration:
I know the relation between angular velocity and angular acceleration is:
However what got me confused is the time, t. If I can integrate my angular acceleration in terms of t then I can find my angular velocity but I don't know the time?
haruspex said:
Any conservation law you might be able to use?
I really have no clue. Maybe energy conservation between the state at rest and when it has traveled d distance? I'm not sure...
Sounds appropriate. What work will F have done on the system?
It would have done:
[itex]W=F\cdot \cos(\theta)\cdot d[/itex]
Right? I'm not sure how to use this in my energy conservation equation.
Why would it even have angular velocity if the force is being applied through its cm?
Because I also have a friction force.
PhyIsOhSoHard said:
It would have done:
Yes.
Where has that work gone? It's rolling contact with the ground, and there's no friction at the axle, so no work has been done overcoming friction.
sorry I thought it was a frictionless surface.
haruspex said:
Yes.
Has it gone to the friction between the ground and the cylinder?
No, as I posted before, that's rolling contact, so the friction does no net work. The work energy is still in the system. What form is it taking? You have a choice of KE and/or PE.
I'd say there is KE. We have KE because the cylinder has a velocity but we have zero PE because our plane is horizontal.
Since I have no PE and the energy is conserved I have:
[itex]K_1=K_2[/itex]
[itex]\frac{1}{2}m\cdot 0=\frac{1}{2}mv^2[/itex]
Because it starts at rest so the velocity is zero.
I also know that the angular velocity is:
[itex]v=R\omega[/itex]
So if I can find an expression for the velocity after it has traveled distance d then I can find my angular velocity as well. Problem is how do I find the velocity...
Suppose it has velocity v. Write out expressions for the angular velocity, the linear KE, the rotational KE and the total KE.
[itex]\omega=\frac{v}{R}[/itex]
[itex]KE_{linear}=\frac{1}{2}mv^2[/itex]
[itex]KE_{rotational}=\frac{1}{2}I\omega^2[/itex]
[itex]KE_{total}=KE_{linear}+KE_{rotational}=\frac{1}{2}mv^2+\frac{1}{2}I \omega^2[/itex]
I'm not sure how it will help me.
Good. You know how to write ω in terms of v and R, and you know how to write I in terms of M and R. So you can get KE in terms of M, v and R.
You previously wrote
K1=K2
but that's wrong. That would be true if no work had been done on the system. The force F has done work on the system, and you already calculated that value. So what equation should you write for work conservation?
