Finding the Center of Mass of a Uniform Disc: A Non-Calculus Approach
The discussion focuses on finding the center of mass of one-fourth of a uniform disc without using calculus. A member expresses difficulty in solving the problem, which involves understanding the shift in the center of mass when a full circle is folded in half. Another participant suggests considering symmetry as a key approach to the solution. The hint provided helps the original poster make progress in solving the problem. The conversation emphasizes the importance of geometric reasoning in physics problems.
Ujjawal Kumar
Hi New member here!
1. Homework Statement
In the figure one-fourth part of a uniform disc of radius R is shown. The distance of the center of mass of this object from center ‘O’ is ……………………….
Given: For a semi-circular disc with origin of co- ordinate system at the center of circle, the coordinate of its center of mass is (0,4R/3π ).
(Solve this problem without using calculus)
I tried for hours but could not find a solution without using calculus.
Hello Ujjawal, welcome to PF :smile: !
A challenging exercise. Think symmetry and folding:
The given information tells you the center of mass shifts from 0 to ##(0,{4\pi \over 3r})## when you fold a full circle in half.
Is that enough of a hint ?
Likes Ujjawal Kumar and SammyS
Yes, and thank you BvU!
This problem actually took me quite some time to figure...thnx for the hint BvU!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
