Finding the derivitive using limits?
  • Thread starter Thread starter ne12o
    Limits
ne12o
Hi,
I've stumbled across a question. It must be solved using limits. I just don't know where to start. After doing the f(x+h) - f (x) / h i end up with a cluster that cannot be simplified... any help would be great.
the equation is as follows.
y = cube root( X^4 - 3X)
Very interesting. I'm not sure how to prove this either, but I'm really interested in seeing the solution!
I think the core difficulty in this problem is with the root, so let's simplify the problem. How do we find f' for f(x) = sqrt(x)?
Then, we can probably generalize to n-th roots and use the chain rule to finish it off.
My guess is that you have to abuse the relation \sqrt[n]{x} = e^{\ln(x^{\frac{1}{n}})} = e^{n \ln(x)}. If you were a brutish proof person, you could probably do something with the taylor series of e^x and ln(x) to solve it with limits.
The difference of two cubes can be factored this way:
<br /> A^3 - B^3 = (A-B)(A^2 + AB + B^2)<br />
This works for any quantities A, B, so (curse the database errors which prevent preview from working)
<br /> a-b = \left(a^{1/3} - b^{1/3}\right)\left(a^{2/3} + a^{1/3} b^{1/3} + b^{1/3}\right)<br />
The numerator of the difference quotient has
<br /> \begin{align*}<br /> a &amp; = \left((x+h)^4 - 3(x+h)\right)^{1/3}\\<br /> b &amp; = \left(x^4 - 3x \right)^{1/3}<br /> \end{align*}<br />
To rationalize the difference quotient multiply by this fraction:
<br /> \frac{\left((x+h)^4 - 3(x+h)\right)^{2/3} + \left((x+h)^4 - 3(x+h)\right)^{1/3} \left(x^4 - 3x\right)^{1/3} + \left(x^4 - 3x\right)^{2/3}}{\left((x+h)^4 - 3(x+h)\right)^{2/3} + \left((x+h)^4 - 3(x+h)\right)^{1/3} \left(x^4 - 3x\right)^{1/3} + \left(x^4 - 3x\right)^{2/3}}<br />
this will leave you with (use the second factoring formula from the top of my post)
<br /> \frac{\left((x+h)^4 - 3(x+h)) - (x^4 - 3x)\right)}{h\left((x+h)^4 - 3(x+h)\right)^{2/3} + \left((x+h)^4 - 3(x+h)\right)^{1/3} \left(x^4 - 3x\right)^{1/3} + \left(x^4 - 3x\right)^{2/3}}<br />
This still isn't pretty, but the work of taking the limit can now be performed.
whoa thanks... now trying to understand it.
thanks!
