Solving Boundary Conditions for Electric Field in Dielectric Media
This discussion focuses on solving boundary conditions for electric fields in dielectric media, specifically between two regions with permittivities Epsilon(r1) = 2 and Epsilon(r2) = 3. The electric field in region 1 is given as E1 = 2y i - 3x j + (5+z) k. The key boundary conditions established are that the tangential components of the electric fields are equal (E1t = E2t) and the normal components of the electric displacement fields relate to surface charge density (∇·D = ρ_s). The discussion emphasizes the importance of understanding these conditions to derive the electric field E2 in region 2.
  • Understanding of electric fields and dielectric materials
  • Familiarity with Maxwell's equations
  • Knowledge of vector calculus in three dimensions
  • Concept of electric displacement field (D)
  • Study the derivation of boundary conditions for electric fields in dielectric media
  • Learn about the relationship between electric displacement field (D) and electric field (E)
  • Explore examples of solving electric field problems in three-dimensional dielectric configurations
  • Investigate the implications of surface charge density (ρ_s) on electric fields at interfaces
Students and professionals in electrical engineering, physicists working with electromagnetism, and anyone involved in the study of dielectric materials and their electric field interactions.
Electro
Greetings everyone:
I'm trying to solve a problem which requires finding the electric field. I've been pondering on this problem for a while but still no results. The book doesn't give any hints or clues on how to tackle this kind of problems so I would really appreciate some of your suggestions.
Assume that the z= 0 plane separates two lossless diaelectric regions with Epsilon(r1) = 2 and Epsilon(r2)=3. If we know that E1 in region 1 is 2y i - 3x j + (5+z) k, what is E2?
What are the boundary conditions on the electric field at the interface between the two dielectric regions?
Thanks Siddharth, but if we draw a picture of the two media, geometrically we can conclude that E1t = E2t where E1t=E1-E1n and the same with E2t (I guess you get the picture). I don't see how this would help. Moreover we are dealing with 3-D ( I guess I might have understood it if it was 2-D).
Thanks
I'm editing the post: Thanks for your help, I understand it now.
Thanks
I'm actually dealing with a similar problem right now. The way I understand it, is that the two boundary conditions are:
E_{1t} = E_{2t}
\vec a _{n2} \cdot (\vec D_1 - \vec D_2) = \rho_s
For the first one,
E_{1t} = E_{2t} means the tangential components are the same. This tripped me up a bit... and I'm still a little uneasy doing these problems. Anyhow you have a plane that separates the media z = 0. So what can you say about the relationship between all the vectors of \vec E_1(x,y,z=0) and \vec E_2(x,y,z=0).
All of those vectors are tangential to the interface. So you can conclude that only the normal component (in this case it would be E_{z2},) is going to change when crossing the interface. Since you know that the tangential components are the same (from the relation above), you are left with:
\vec E_2 = \vec a_x E_{1x} + \vec a_y E_{1y} + \vec a_z \bar E_{2z}
where the bar was used for emphasis on\bar E_{2z} (the z component of the vector).
  • · Replies 16 ·
