Finding the limit of this expression
8 replies · 3K views · last reply
turutk
The limit of [tex]\frac{8x^3+x^2-5x}{3x^4-5x^2+2}[/tex] as x goes to 1
Evaluate this limit algebraically.
Tried using 1 instead of x. The denominator becomes 0.
Divided denominator by (x-1) but couldn't continue.
When x is near 1, the numerator will be near 4, which is a positive number.
When x is near 1, but larger than 1, the denominator is near zero and is positive. When x is near 1, but less than 1, the denominator is near zero and is negative.
Can you conclude anything from this information, about the limit of your rational function as x approaches 1?
does that mean limit does not exist?
Mark44 said:
Yes, but can you clarify how you reached that conclusion?
at first thank for your help
i believe so.
while x is approaching 1 from + side the denominator gets closer to 0 which makes the limit positive infinity as x approaches 1+
while x is approaching 1 from - side, the limit becomes negative infinity.
one side of x=1 goes to -infinity the other +infinity so i conclude that the limit does not exist.
now i am working on this limit:
greatest integer(sinx) / greatest integer(x)
x approaches to 0
i predict that result will be 0 but i am not sure
[tex]\left\lfloor[/tex]
i believe so.
OK, good. Since the left-side limit is different from the right-side limit, the limit itself doesn't exist.
x approaches to 0
I don't think it's zero, but I'm not sure, either. I would make a table of values of x and sin(x) values for x near zero on either side. Keep in mind that when -pi/2 < sin(x) < 0,
[tex]\left \lfloor{sin(x)}\right \rfloor = -1[/tex]
Mark44 said:
[tex]\left\lfloor[/tex]OK, good. Since the left-side limit is different from the right-side limit, the limit itself doesn't exist.
turns out it is zero:
http://www.wolframalpha.com/input/?...nx))/greatest+integer(x)+as+x+approaches+to+2
i still cannot explain
